Engine cut-out when turning on the lights
  • Engine cut-out when turning on the lights
    Hello, I have a Suzuki Swift 2007 1.3lt with F3 ballasts, Cnlight bulbs on Mini H1 projectors with bixenon wiring harness. I had the F3s for more than 5 years without any problems. Recently one F3 failed (never started again) and I replaced it with a new one. Days later I replaced the second one since i noticed that I started getting engine cut-outs (like the engine stops for 200 or 300 milliseconds while driving) the moment I turn on the lights. Problem solved for weeks but now it appeared again. It now appears once in a while, not every time I turn on the lights and only when the bulbs are completely cold. Could it be an overcurrent draw at startup or a EMI issue (one ballast is placed next to the ECU - I know, not a wise placement). My battery and alternator are in good condition.
    Any advice will be appreciated
    PS: will a warning canceler capacitor help with impulse current draw at startup if put just before the ballasts? I suppose its an electrolytic capacitor in parallel with the power supply?
    Do you have relay harness? If you turn your lights on and your engine cuts out, you have an electrical/charging problem.
      If you are running without a relay, I would recommend getting one.
      If you are running with a relay, check both of your battery terminals to make sure they are tight. Then check your big three to make sure all are secure.
