Boosted Hella gen3 problem
  • Boosted Hella gen3 problem
    Hey guys I need some help. I got a pair of boosted Hellas (46w) and one side flickers or it sometimes just quickly turns on and off as you can see in the video. Right now the driver side has Hylux fast start and the passenger the Hella. When I tested both side with the Boosted Hellas again just one side works. I'm using Morimoto relay harness with upgraded Hella relay and 40a fuse. If I switch just for Hylux ballast it works just fine. What do you guys think it could be? Can-Bus problem in just one side? I have never used it before. Please any help would be much appreciated. (obs: non boosted Hella works just fine and the car is 2017 Mazda3) Thank you
    So you've tested both boosted ballasts on the working side?
      Yes I did try both and also I bench tested them and they worked. Just Hella 35w also works just fine.
