LED beam pattern on new projector headlights is showing two bars
  • LED beam pattern on new projector headlights is showing two bars
    Greetings all,
    I swapped out my stock headlights for ones with projectors and am using LED bulbs.
    Does anyone know what could be causing this wired beam pattern? I see two bars, instead of one clean, crisp, bright one.
    from inside the car 1
    from inside the car 2
    outside of the car 1
    outlined example
    any help is appreciated.
    adjusting them fixed the issue
    from inside the car 1 - fixed
    from inside the car 2 - fixed
      Who knows really. You installed a set of poor quality headlights that do nothing but throw light on the ground with a fancy cutoff and no real light control. And then put a horrible set of LED bulbs with no optical performance.
      Not trying to bust your chops man but please reinstall new OEM headlamps and then look at a high performance H11 bulb or other good LED bulbs. (search my posts)
        Yeah even after you adjusted them, you have 0 distance. Those LEDs are trash and should never be used.
          thanks i will review your posts and see what i did wrong.
            Basically, an LED is supposed to mimic a halogen filament. That LED does not, it just throws light everywhere. You need a quality set of LEDs. The other problem is that those aftermarket lights tend to have mediocre to terrible projectors (depends really). But fix the first problem first.
              Good thing is now you can retrofit
