High RPM idle with HID
  • High RPM idle with HID
    Noticing car is idling @ higher RPM when HIDs are turned on and left on. Jumps from 600RPM to almost 1K RPM and stays like that.
    Is this normal?
    No. What car? Do you have relay harness?
      10th gen civic
      no relay harness
        sounds like that kit or installation is really draining the system, causing the alternator/engine to kick into higher RPM to compensate. Not normal, not really no
          I would remove whatever you've installed in case it damages something. I've never had idle jump and OE systems don't do that.
            That's pretty unheard of. What kit did you install? Try a relay harness, but you may have a defective kit.
              hylux ballast, CN light, both from ebay.
              here's a video, HID turned on @ 15 second mark (already warmed up):
                Bump
                Any input please?
                  Not normal at all , are your ballasts 35 watt or 45 watt ? I would definatly install a relay harness .
                  I can turn on 3 sets of 45 watt ballasts and 2 high powered light bars , and my idle doesn't increase at all
