D1S for 2003 Seville?
  • D1S for 2003 Seville?
    Hello everyone, first post but I've been digging through the site over the years and love all the information provided!
    This past summer I picked up a 2003 Cadillac Seville for cheap to use as a winter beater, and it's got factory D1S projectors. When I got it I could barely see at night, however the lenses were in terrible shape. I restored the lenses the best I could (500 grit, 800, 1000, 3000, medium polish and finally a fine polish) and that helped a ton, but I'm quite sure that after 130k miles and 16 years the factory bulbs are as tired as can be.
    It looks to me like the CBI's are probably my best bet, however they're a little pricey for a "beater" car, although the rest of the car is in good shape and I do plan on keeping it as a spare car so if that's my only logical option I'm not against it. That being said, are there any other decent D1S bulbs that will do "ok" duty in an "ok" beater car? I can't imagine anything is worst than what I have now, but I don't want to have to yank the lights out 3 times because of flicker or some other nonsense.
    So what say you, all mighty HIDPLANET minds?
    Osram or Philips
    $160/pair for CBI from Lightwerkz or TRS, versus $72 each for Osram standard from powerbulbs, about $20 difference.
    You can take your chances with cheaper bulbs, but I would "spend once and forget about it for 5 years" and get Osram standard (for the colour).
      Bulb upgrade is great but the sevilles come with Hella E55 projectors and they are notorious for the bowls burning over a period of time of use.. Personally i would do a evoxr 2.0 swap with better performance..
        That's funny, I was actually curious about just what "brand" of projector Cadillac used, and low and behold I got an answer.
        Thanks for the suggestions, but I kind of jumped the gun and went ahead and ordered CBI's from HID Concept for $127 shipped. Best deal I found anywhere, and from what I read on here he's reputable. I'll take some before and after pics for everyone to see. I know it's an old car in the world of lighting, but I figured if the original bulbs lasted 15 years I should just go OEM quality.
          You made the right choice when it comes to bulbs. OEM is always best. Let's just hope the projector bowls aren't burnt. If they are, your output will still be bad.
            Let's hope so. They're supposed to be delivered to the shop today, but it started snowing AGAIN and traffic is already jacked.
            If my projector bowls are burnt, how bad of a swap is it to the EVOX-R 2.0? I have no problem taking the headlights apart. Also, everything I've found refers to the E55's as bi-xenon, which my car certainly does not have. It has regular halogen hi's inboard of the projectors. Did Cadillac just not wire up the shutters on their version of the E55's?
              Huh, maybe they're not E55s. Unfortunately my knowledge of the Seville is quite literally 0. So I'm not sure if the EvoX-R 20 is a direct swap. I am not sure if there are low beam only E55s but it is a possibility.
                Well, the bulbs came today! I must say the packaging is beautiful. Unfortunately I won't be able to install them yet, the car went out on loan to a friend in need last night.
                I'll make sure and get pictures before and after for comparison.
                  Well, I got them installed. I can definitely tell they're brighter, that's for sure, but the color just isn't there. I did notice that the lenses on my car are almost a yellow/purple tint.
                  I didn't grab and pictures yet, but I did find a link to a place selling an "unknown" projector that looks JUST like the one used in my assembly:
                  http://factoryxenon.com/shop/factory...-for-retrofit/
                  Anyone know what type of projector that is? I can't find any other D1S projectors that use a strap design like that to hold the bulb in place.
                    Originally posted by alec2538 View Post
                    I did notice that the lenses on my car are almost a yellow/purple tint..
                    I would fix that first before spending money on anything else.
                      Sorry, not those lenses. The actual projector lens has a purple tint to it.
                        I've seen that before on a Cadillac.. Does the color get warmer than it should? Blue/purple tint usually warms up bulbs.
                          Err umm what, okay. Got pictures?
                            It's much warmer than the photos of other CBI's I've seen. It's really not far from halogen, just with a lot more intensity. I would say close to... 4,500k? FAR more yellow than they should be, or what I anticipated them to be I should say. I'll try and get pictures tomorrow, it's so freaking cold in MN it's hard to do anything.
                              Hmm that's crazy if it's a whole 1000K difference. Not much you can do about it except for step up to a CBB to get a bit more coolness, or a 6500K aftermarket bulb really.
