11 Silverado rad support
  • 11 Silverado rad support
    Hi everyone. Im going to be putting a retrofit into
    my 2011 Silverado and I hear the rad support will have to be cut to get it to fit properly. Does anyone have any photos of what has to be cut and what you used to do it? Thanks!
    Hi there yes you will need to notch it in depending on what projector and bulbs you are using. If you had mini h1 I would think you should clear. I had to notch mine a bit I used rx350 projectors for my 08 Sierra Denali. I'll see if I can find I can find some pictures. I used a cut off wheels but a hole saw would work too.
    https://drive.google.com/file/d/0Bxi...w?usp=drivesdk
