HIGH beam modules in fog lamp assembly?
  • HIGH beam modules in fog lamp assembly?
    Can we install the generic profile hi beam led module in a fog lamp assembly to use as a high beam? Will that be too low for them to work properly as a high beam? Any output shots if someone has tried these?
    Basically my car has small headlamps and fitting a projector and the high beam module together will be a tight fit and look awkward as currently it has a single H4 setup.
    this is the high beam module i am looking at:
    You don't want your high beams to be that low, it'll hit the road early and cause a lot of foreground. Do you feel you need better high beams than a quality bixenon projector?
