What to use to fill holes
  • What to use to fill holes
    Finished retrofitting some 4.0s into my denali headlights, but i have some larger holes to fill now. Last time i used permatex silicone but it left a greasy feel on the rubber on the headlights. If a person found butyl caulking would that work? Or what do you guys recommend?
    What do you mean fill holes? Generally people put a rubber boot on the back of the headlight.
      The black plastic pieces around the frame, with what looks like a hole for screw at the bottom and top; doesn't that mate to an end cap that can cover the back of the projector? What does that look like? Maybe you can extend that cap instead of making an entirely new seal for the back of the projector?
        There is no end cap. The original projector was a sealed unit. When i retrofit to a 6.0 i had to silicone the plate and around the projector. With the 4.0, the was a considerable amount of extra cutting to make it fit.
          Oh I see. Why not JB Weld?
            Would need to be suoer thick to fill the holes. I was thinking of jb weld steel stick to fill the holes, then the 2 part stuff to finally seal it. Thats if silicone and butyl caulk are a bad idea. I dont think i will be able to retro these again so JB is a strong possibility, just never used it before.
              Some silicones outgas, gotta be careful. I just never used silicone in any headlights before so I can't comment. JB Weld is safe and strong.
                Well, i used steel stick to fill most holes and then jb kwik to cover everything exceot the holes for the plugs for the high beams. Guess those i will have to silicon, dont think its a good idea to jb weld those plugs in to fill the holes behind them...as tempting as it is since im at work, its midnight, i have no silicone, and i want to get these lights in the truck for the drive home now lol
