HID kit = bad cutoff
  • HID kit = bad cutoff
    hello , im new here.
    i installed a new aftermarket headlights to my polo gti 6R.
    i also bought a new HID kit of M-tech
    https://www.powerbulbs.com/product/m...n-kit-h7-5000k
    but the cutoff is really bad.. its not straight. as you can see..
    what could be the problem ?
    thanks.
    https://ibb.co/m45AVe
    https://ibb.co/d5mOiz
    https://ibb.co/n6bvwK
    What do the beams look like when you install name brand (Osram/Philips) halogen H7 bulbs? Does the beam pattern improve?
    If the answer is YES, then the problem is the HID bulbs. They are either not seated correctly or poorly constructed/designed.
    If the answer is NO, then the problem is the headlamps. They are poorly manufactured and have low quality/cheap projectors. Which is common for aftermarket headlamps.
      i didnt try to install other bulbs yet . i will do as you told me.
      by the way - where can i buy a good HID bulbs from ebay ?
      thanks
        Lightwerkz store. They carry Morimoto and NHK retrofit bulbs.
        https://www.ebay.com/sch/m.html?_ssn...kw=h7&_sacat=0
          thanks these bulbs will fit with my M-tech HID kit ? https://www.ebay.com/itm/Morimoto-HI...RBZRxYF3xeclKA
            The problem is the shitty aftermarket headlight projectors.
            Do a retrofit with proper projectors in this or the OEM headlights, I would go for the OEM.
            Those CNLight HID bulbs are usually ok. They could have little misalignment (that shimming resolves it), but nothing like that.
            Chevrolet Astra 2.0
            OEM Hella E55 frosted lens with 4-position Eletric Leveling
            Yeaky 5500k @ Hyluxtek ASIC DSP 50W
              are you sure 100% that the problem is my aftermarket headlight projectors ?
              i would like to try other bulbs but i am not sure if it will be fine after the new ones.
              *i dont have time and money for other solution like retrofit right now.
              thanks again.
                Can you post pictures of one headlight on a wall at a time? It looks like one is way wacked up and the other might be OK. Also, got a link to where you bought the headlights from? They might not be trash, kind of look like some of the Chinese ones that used a decent projector like the Q5R.
                  here is the link of the headlights :
                  http://www.eagleeyes-asia.com/shop/v...-p-type-09-18/
                  https://marsperformance.com.au/Black...-POLO-6R-10-16
                  i will take a picture of one headlight on a wall tomorrow
                  bitter - i agree with you .. its looks like the driver side might be ok..
                    Well I think never mind about it being a Q5R, those are bixenon and use a D2S bulb.
                      bitter what do you mean D2S bulb ?
                      i am using H7 HID right now .. should i replace them to D2S bulbs ?
                      This will solve the problem ?
                      what is good one from here ?
                      https://www.powerbulbs.com/store/cat...ting/d2s-85122
                        The second link shows the back of the housing open, where the bulb opening and spring mounting clip is in the picture. I see how they say it is H7 halogen, but can be "upgraded" to HID. So the "upgrade" is a rebased H7 HID.
                        evo77 suggested a check, where if you put OE H7 halogen bulbs, does the output still look poor or not. If it looks poor, then HID won't help. If good H7 halogen bulb generates good output, there's a chance that a rebased H7 HID can be ok. Although one should note that OE HID bulbs do not come in the halogen-standard H7 base. They are D1S, D2S, D3S, or D4S for projectors. The location of the HID arc relative to the base (and the rest of the projector optics) and the projector optics design determine the output quality.
                        Aftermarket headlights do not have to come with good projectors; many have terrible outputs but look "bright".
                          what is OE ?
                          if the OE H7 halogen will be good . then could i try the D2S ?
                          or only another bulbs rebased H7 HID ?
                            OE = Original Equipment
                              Replace projectors with HID projectors.
                              While you save up money and time, replace HID kit with halogen H7 bulbs.
