I recently bought an after market projector with HID, after some rough shim of light bulb, I got the following cutoff and light pattern. I tried to move the hot spot up to be close the cutoff line, a big glare will be created. Even in the current case, small glares are observable on the top of the cutoff line. My question is if this is the best I can do, will it be OK to use with current alignment?
Thanks
Thanks
