Boosting and lifetime of bowls
  • Boosting and lifetime of bowls
    I am planning to re-do my retrofit and i want to use boosted hella gen3 ballasts (not 55w boost, but something between 45-50w) and i am wondering if there is any projector that is more sensitive to excessive heat and one that has no problem with it.. i am leaning towards open projectors, (rx350, 4,0 ) better heat dispersion maybe?.. Anyone running 50+ watt in long term? Thanks for any hints.
    Open projectors deal with heat better. The additional UV damage on the bowls from boosting a bulb will have a bigger effect than heat, though. OEM open projectors work the best long-term, though, for boosting.
      The Mini D2S 3.0 and 4.0 are advertised as safe to use with 55w.
        Imho, as even OE projector's bowls sometimes brown, there really is no absolute guarantee that the choice of power and bulb will prevent damage from happening.
          Most of the quality projectors can handle 55w, but make sure you use OEM bulbs. the burning isn't from the heat, its from the extra UV light given off, and the cheap bulbs give off more UV vs the OEM ones to begin with
            Yup. And LED bulbs put out 10,000 lumens as well...
                Yes i will be using just about all oem , but i am considering d2s 4īs also, i know it will burn eventually , i donīt have sealed headlights so it is not a big deal to replace bowl but i donīt want to do that every 6 months or so..
                Maybe someone who is running 55w for some time to share?
