How would I go about doing this? I know how to take it apart and what parts are what, but I am unsure on what to paint. I also know I need to paint the front of the cutoff shield, but should I also paint the front of the metal that it is attached to(the limiter?)? Any suggestions how not to screw up the shield and cutoff would be great too. Thanks.
Painting Mini H1 for Demon Eyes
You can paint the front of the shield as well as the foreground limiter. Just be careful to not paint the solenoid if you don't remove it. Also, you might want to lightly wetsand the edge of the cutoff shield in case any paint built up along it.
Also.... what MH1 are you using? My advice is for a 5.0 or older, not sure if the 6.0's are assembled the same way.
I've got a 6.0 but from what I've seen it is nearly identical to the 5s. I don't think i will have a problem with the mechanics of it, I'm just worried that the light output or cutoff may change after putting it back together and even though I work with theater lighting every day, this seems a little more exact and fragile. I assume if I don't bend anything or coat the back sides I should be good. Thanks for the fast response!
Why not paint the front of the solenoid too?
Retrofit Build Journal
Tuned Morimoto Mini H1 V5/6 Hybrids | XB35 4300K | Morimoto 5Five DSP
Hella 500 Black Magic | Catz Zeta
2002 Jaguar X-Type AWD 2.5 V6 (planning quad retrofit!)
Another option would be to place a thin sheet of metal in front of the solenoid box, and then paint that sheet. No risk of getting any paint residue contributing to a sticking solenoid.
Like this (although I did this on a Mini D2S v2.0 and for a different reason):
http://www.hidplanet.com/forums/show...-Mini-D2S-v.20
Maybe.
I prefer to paint something that can be taken completely far away from the sensitive solenoid assembly.
Originally posted by satrya View Post^
Maybe.
The method I used (linked) was inspired by a fellow member's method, EvoXenoN. I substituted sheet metal for the original soda can.
