Body Filler Over Foam Shroud
  • Body Filler Over Foam Shroud
    Probably going to make a custom foam shroud after I finish mounting my hacked up LED fogs. The foam is 'polyurethane' two part mix. What body filler can I use over top that will not eat it? I bought this for a project a while ago and never used it but now is the time.
    https://www.siriusrocketry.biz/ishop...-foam-771.html
    i think it just needs to be 'plastic safe' or 'polyurethane safe'
    when i did my abs-plastic tails, evercoat fibertech was recommended for the filler. looking around their site, i don't see anything better to recommend(look under reinforced fillers for similar, plastic-compatible fillers), and glaze-it finishing putty, again both of these products are specifically recommended for plastic filling/smoothing applications, though i'm not sure anything is recommended for foam. some foams are a little unpredictable as far as what eats them...
      Use 3m ez-sand multi purpose repair material. (2 part epoxy) Very sandable, and metal glaze can be applied over it.
      part number 05887
