So I'm trying to retrofit the morimoto mini h1 into my 2012 toyota camry fog lights. The projector is huge so I had to cut out the back side of the fog housing and now I have it positioned nicely.
i think what i will do is use silicone to seal the foglight to the projector, then use a cup of some sort, cut a hole for the projector rear end screw, and weld the two plastic peices together.
what could i use to weld two plastic peices together solid?
any suggestions appreciated. thanks!
