JnC's Projector-Mounting Method (with Rotational Adj Capability)
This topic is closed.
This is a sticky topic.
  • JnC's Projector-Mounting Method (with Rotational Adj Capability)
    Here is the thread on the infamous, tried-and-true JnC Method for mounting projectors with hardware so that it has vertical and rotational adjustability:
    JnC's Mounting Method (with Rotational Adj Capability)
    The alternative to this method is using glue/epoxy to hold the projector in, but of course you have to get it 100% spot on, or else be stuck with mis-aligned projectors.
