Morimoto Mini D2S 5.0 Projectors Installation Help
  • Morimoto Mini D2S 5.0 Projectors Installation Help
    I getting ready to install these projectors and noticed the silicone washers appear to be misshapen. One half it thicker than the other. Is that correct? What is the best way to install them on the projectors when mounting them through the headlight reflector bowl? Since they are thicker on one side, aren't they going to make the projector point toward the thinner half somewhat? Are these silicone washers even needed for installation? Thanks.
    Turn them the way you need them mist reflector bowls are not uniform below and above the bulb hole.
      Some headlights may not need the washer, you just have to test-fit the projectors a few times before locking them down. It's purposely "deformed" because the projectors have a downward tilt, so usually the thicker part is at the bottom to compensate for the tilt.
