any 2.8" lenses available?
  • any 2.8" lenses available?
    Hi all,
    Trying to do a clear lens swap on my old Golf Mk7 GTI projectors. If they perform better than OEM (which I think they would), I will put them into my new headlights. I managed to get the lens off the projector (seems like it's glued or pressured onto the frame? The projectors looks like this:
    The front black part with the 2 legs is the same as on my projectors (one leg in the bottom). The projectors should be totally alike and the seller states that these projectors use 2.5" lenses, however I measured the one I got out to be 7cm or 2.8". 2.8" seems like an odd number to me, I suppose you have to measure from edge to edge, to get the correct width?
    Never the less, I would be happy if some people would know if there's any 2.8" clear lenses available on the market today? I could also do with the clear lens built into the black 3-legged front. Unfortunately a projector swap is a no-go for me since I have dynamic highbeam on my golf.
    I have 1 of these projectors.
    AFAIK its only that lens that it takes. Its actually a 2.75in projector.
    I just need another one then I'm happy
    1999 LR Discovery II XS 4.0L V8 auto - Halogen
    2012 Ford Figo TDCi - E46 projectors - XB35 ballasts - 4300k Bosch D2S bulbs - G37R shrouds - BIXENON stickers - H4 Mori wiring
      God damnit... I was really hoping a clear lens in that size would be available out there.
        For stock projectors they aren't bad. I love its weight. Cant wait till I have a pair in my car.
        Here is a link on a bit more info on them.
        http://factoryxenon.com/shop/2x-oem-...or-retrofit-2/
          If I query the aliexpress website for a 2.8" projector, I get a few generic aftermarket ones.
          It's unclear whether the focal length is in a compatible range with your projectors (looks similar to Audi S3 iirc), and whether or not the outside diameter (listed as 2.8") is actually close to what you need.
            I agree that the OEM projectors are pretty good, however I've been used to the clear lens with super sharp cut-off (got Evo-X on the old car), so it's hard to deal with this.
            @Satrya, thanks I looked a little bit. TRS doesn't seem to be able to source these. I just tried to compare the focal point of the OEM fresnel lens with a ZKW lens and they seem to be the same.
              How wide are those G7 projectors?
              Everyone I ask to look at their headlights look at me in a weird way??
                By "G7", did you mean that same projector OP posted? But you have one, right?
                From TRS's Mega Projector thread ( http://www.hidplanet.com/forums/show...r-Post-via-TRS ), it looks like the Audi S5 ones:
                  yup only have one. Got it free. Hoping I can get another tomorrow.. And still waiting for my one friend on info regarding ballasts.
                  if thats them they aren't soooo wide. But wide fogs will make up for that
                    Is that projector with a clear lens? :O
                      Aren't the Mini D2S 2.0 fitted with 2.8" lenses?
                      My retrofits
                        The round MD2S is 3 in.
                        The square MD2S is 2.75 in.
                          Mini D2S 2.0. Previous generation.
                          My retrofits
                            Think they were 2.5in projectors.
                              I didn't measure the Mini D2S 2.0s I have; but I've placed the lens back-to-back against the TL and RX330. Both have a larger diameter than the Mini D2S 2.0. There may be generic aftermarket versions that advertise themselves as having a 2.8" lens, but that may just be including the plastic lens holder; I'm not sure.
