Mini H1 colorless
  • Mini H1 colorless
    It's a mini H1 of last year, about same time of year.
    Of the two i bought, one has no color, or not so, it's got a slight yellow-orange line, also cutoff doesn't look too sharp..
    Thinking about it, it also looks a little dim compared to the other one... i can swap bulbs to rule that out also.
    I'm having a alignment problem that needs to be adressed and while at it i'd like to give it that blue cutoff the other one has.
    Is it cereal box spacer time or bending stuff time?
    Thanx.
    I'd check the hotspot location first before adjusting the shield spacing
      Alright, then what do i need to do if it's in the wrong place?
        Maybe move the bulb around first
          That.
          Once the hotspot is at its best location, then any tweaks you make on shield spacing etc. will be referenced against the most correct bulb position. So, even if the bulb seats a bit differently once you put everything together in your vehicle, you can always nudge the bulb and figure out a way to keep it in that position. Then, everything else you did to make it better should work.
            working on it right now, first thing i notice, they have 3 small washers on all bolts to space the lens.will try different bulbs and also try to mode the bulb a little.
            Whats a common practice to have the H1 bulb to sit differently?
              Found the problem.... shield not returning completely.... now how to fix that?..
                Well I've seen people shim the bulb but I prefer to just move the shield if the hotspot is really off.
                  Sticking solenoid or there's something obstructing travel?
                    Just finished screwing with it... grinded like for ever but for now it returns at the right place
                    Was sticking on the plate that holds the solenoid... well the high beam cutoff i could say.
                      tweaking such gizmos from hell must have made lots of nervous breakdowns to guy's like me...
