Philips broke into the automotive LED market a year or so ago with the first real compatible halogen bulb replacement for fog lights. The H11 bulb carefully places 3 tiny led chips in a row in the exact location as a halogen filament. The result is a beam pattern exactly to that of halogen but in a brilliant 6000k light.
It was only a matter of time that they take what they've learned and apply it to headlamps. This time using a "dual filament" design to mimic the low and high beam. If you look closely there is a shield on the row of chips for the low beam. This is to reduce glare.
Now how long will it take before other applications are offered?
12953BWX2
Maximum road safety and style
More bright light on the road, without glare
Philips LED intense bright headlights bring a sophisticated & modern light appearance to your car, and maximum visibility with +150% more brightness on the road than halogen lamp, for maximum driving safety and visual comfort.
Maximum road safety:
+150 % more light on the road*
SafeBeam to not glare other drivers
12 year lifespan:
3 year limited warranty for consumer usage
AirFlux thermal design
The prefered quality of car makers
Intense bright light:
Intense bright headlights
Specifications
Technology:LED
Application: Headlight high beam, Headlight low beam
Type: Headlight H4
Color temperature: White 6200K
Lifespan: 5000 hrs
Voltage: 12 & 24 V
Wattage: 23+/-15% W
Designation: X-treme Ultinon 6200K
Range: X-treme Ultinon LED
Issue date 2015-07-30 Version: 1.1.2
12 NC: 8670 001 31855 EAN: 87 27900 39410 8
Base: P43t
Lumens [lm]: 1000+/-15% LB, 1250+/-15% HB
Logistic data
EAN: 8727900394108
Ordering code: 39410828
Quantity in box: X2
Referen
Highlights
For your driving safety and visual comfort, you need to project light on the road ahead far and bright, without glaring the other road users. With an optimized optical design, Philips LED headlight brings you maximum visibility, with +150% more brightness on the road* where you need it most. (* than standard halogen lamp)
Optimal thermal design for maximum cooling of LED to ensure ultra-long service life
Philips LEDs headlights 6200K provide the most intense light upgrade solution to your car, with a perfect color match with LED fog and LED position lights, for a sophisticated and modern light appearance
Prefered quality of car makers
In the world , 1 out of 2 cars is equipped with Philips lights. Philips is the supplier of choice of all major car manufacturers.
SafeBeam for other drivers
Philips patented SafeBeam optical design brings maximum visibility with a beam pattern that does not glare other road users. Similar or better beam pattern than standard halogen lamp, ECE beam pattern compliant*. * There is no ECE regulation existing for LED bulbs. ECE beam pattern compliance is tested on several commonly used luminaires where the LED bulb beam pattern matches the ECE approved halogen beam pattern
12953BWX2
12 year lifespan:
Specifications
Technology:LED
Type: Headlight H4
Lifespan: 5000 hrs
Voltage: 12 & 24 V
Wattage: 23+/-15% W
Base: P43t
Logistic data
EAN: 8727900394108
Quantity in box: X2
Referen
Highlights
