2004 Prius Canada DRL - Halogen to LED Projector Headlight Retrofit - Morimoto MLED 2.0 - Troubleshoot
  • 2004 Prius Canada DRL - Halogen to LED Projector Headlight Retrofit - Morimoto MLED 2.0 - Troubleshoot
    I am trying to install Morimoto M LED 2.0 projectors (morimotohid.com/morimoto-m-led-2-projectors) in my 2004 Prius--originally with H4 halogen bulbs and Canadian mandated DRL.
    I'm using the Morimoto H4 bixenon relay harness (morimotohid.com/morimoto-h4-motocontrol-wire-harness) to wire the headlights, according to the instructions here: morimotohid.com/core/media/media.nl?id=1718916&c=5129608&h=8871d5b244d6f6a540 50
    The relay harness plugs in to one of the factory headlight harnesses, but the other side is left unplugged. Each projector headlight is plugged into the harness, which powers the bulbs directly from the 12V battery post by acting as a switch from the factory harness.
    I connected everything according the instructions, but the projector headlights do not turn on. However, if I plug an H4 bulb into the empty factory harness (opposite from the relay) that new bulb will light normally.
    I think the issue has to do with the wiring of my car or the DRL. Please help me fix this!
    I was searching if it was a common issue with your car and found you on priuschat
    2006 Grand Vitara 3dr
