Nearly plug and play option.. HID to LED swap due to bad HID design in Lincoln MKZ
  • Nearly plug and play option.. HID to LED swap due to bad HID design in Lincoln MKZ
    If you have a 2017 - 2020 Lincoln MKZ you can install the OEM Headlights using Forscan.
    EDIT: just erased 35 minutes of typing and instructions because it was too long. OEM HID sucks on this car even with Night Breaker Laser which worked great on my other car. The OEM LED headlight is nearly Plug and play despite what some websites that try to sell you harnesses say. IIHS confirmed that the HID lacks in recommended distance while the LED exceeded.
    After swapping them over and doing some very small changes using FORScan, they work great.
    Great. Do you have more pictures on the wiring?
