Which Bi-LED projectors are in the MLED/MD2S 4.0 bracket family?
  • Which Bi-LED projectors are in the MLED/MD2S 4.0 bracket family?
    I want to go LED on my G37... it's up there in age and I imagine the bowls are starting to burn. I want to go LED rather than HID because for the price of a decent pair of bulbs I can have new optics and chips that will outlast the car.
    Anyway which Bi-LED options out there share the same mount points as the MLED? I know the DMEX does and I think I will just get those, but I wanted to know if there were any other options.
    Have you checked my aftermarket biled thread and compared all the ones listed there?
      I checked the thread but didn't compare them. It's a lot to go through. I figured it someone else knew already I could just ask.
      DMEX is about what I want to pay, has the right bolt pattern and has a nice beam pattern so I think I'm just going to do that.
        Where do you plan to get your DMEX from? Just be aware that there are TWO versions. One with a Seoul Semi chip (claimed) and the other is a Osram Ostar. Of course the Seoul is cheaper and may exhibit a different beam pattern versus the Osram. And honestly by the images I've see of their claimed Seoul chip, it looks nothing like anything Seoul has in their portfolio. Unless its a custom Seoul, which I doubt too. Probably some unknown Chinese LED chip.
        Check out this new biled I've seen on Ali. It uses a Genesis Photonics (Taiwan) chip. And while I know that GPI is a pretty unknown LED company, at least there are some published specs (no datasheet) and the chips are specifically made for automotive lighting.
          Interesting. I was just going to order them on Alibaba. I can't see the Lightwerkz page at work but I'd like whichever version he had in the video.
            I asked this question on their FB page but they never replied.
              I cannot find the Osram DMEX. I might go with the kit you posted. Or just pony up for the MLED and flip the chip.
                I ordered the AOZOOM about 5 days ago. It's on the way. I'll be able to compare it to the DLAND JSP projector I have as well. I'll look for that OSRAM DMEX, I remember seeing it, just can't remember where now.
                  Here's what I consider the first version of it:
                  https://www.aliexpress.com/store/pro....2680465D00hs1
                  I ordered it and was not thrilled with the width, And the intensity faded as the chip/heat sink heated up. Discussion here:
                  https://www.hidplanet.com/forums/for...-led-projector
                  Another:
                  https://www.aliexpress.com/item/Free...c1425f4a&tpp=1
                  Here's the one you can choose the chip:
                  https://www.aliexpress.com/store/pro...781446657.html
                    I picked up a set of the i.lens BI-LED projectors. It has a 5000k color temp with one of the widest width of the LED projectors I've seen. I originally purchased the MLED but the short width steered me from them and I returned it
                    https://hidkitpros.com/shop/bi-led-p...nlight-lens-2/
                    G5-R vs i.lens BI-LED
                    https://www.lightwerkz.net/photo/out...arison-2/#next
                    i.lens Bi_LED vs MLED
                      I am just leery about reliability. Even with a good chip the driver can be shit. I might just go clear lens on my G or if the bowls are burnt throw in some Q5s.
