Help Needed with ACME Sequential Switchback
  • Help Needed with ACME Sequential Switchback
    Hey guys, so I was doing a custom install and I bought the new ACME Sequential Switchback LED strips from TRS, I removed the silicone at the end of the strip to see where each wire was soldered to for reference and now the strip is not working correctly? With the ground and power wire hooked up the strip is lighting up amber when it should be white, it's also not very bright. It should be turning on the white LEDs only with this setup, and they worked fine before I removed the silicone. What do you guys use to replace it as it almost seems like a power draw of some sort from the power to the amber inputs?
    Thanks in advance.
