Im looking for a local store to find these. Can't seem to find these in hardware stores... Any other suggestions? hobby shops?
What type of stores have 6000grit sandpaper?
Oh, i need it to restore the inside of my plastic lens. I guess ill try using the nova plastic this weekend and hope that thatll be sufficient.
ps. i tried all the plastic polish, rubbing compound, and 3k grit sandpaper and I still get a nasty fog. i hear that is that the inside of the lens is really sensitive..
if you need anything over 2500 and a good polish your not doing someting right.
try the 2500-3000 then a good compund with wool pad steped down to a lighter compound and then a polish or glaze with a foam pad.04 sti
FX-R, 85122+ oem ballasts.
Only place around me that has it in stock is a hobby store. You can order it online many places, I usually only go to 2000G then to compounds, and polish. Here's one place that you can order it from if you want some 6000G.
http://www3.towerhobbies.com/cgi-bin...&I=LXYCK1&P=FR
my friend did that 3m headlight restoration thing and his left a bunch of fogginess and yellow. Anyways I done it for him a couple weeks later and it worked good. The key is to remove everything with 400 grit first then after that your just sanding out scratches
hrm.. how is is that on my mom's camry, i was able to use 2k grit and then rubbing compound to get great results.. but even when using 3k sandpaper, i seem to be going nowhere w/ my vw headlight (im doing the inside of the lens, not the outside). oh and i did try using 800 grit to "re-do" my sanding and went back up several times, but no luck
Originally posted by mrcandyman17 View Post6000 grit is wonderful. I'm Canadian but I get mine in either Home Depot, Totem, Home Hardware, Rona, Peavey Mart, Canadian Tire, and I'm sure there's other places nearby that have it too.
