Need Help Opening Aftermarket Tails
This topic is closed.
  • Need Help Opening Aftermarket Tails
    I am trying to open some aftermarket tails to paint them the same color as my truck. They appear to have some type of glue on the inside (the gray-ish clear in the below photo) that may come apart with a heat gun or the oven method, but I am not sure if this is the actual glue that holds the lens on. And after completely butchering the 3rd brake light to try to do the same thing, I am hesitant to just jump right in. The 3rd brake light appeared to be plastic welded that I tried a heat gun, razor blade, hot razor blade along the seam and wound up cracking the living hell out of it.
    I am thinking I will need to cut into it from the back, but before I jump into this, I would like any and all advise please!
    Anyways, here are the pics!
    You can see the glue here
    There is some weird tab here that I afraid to tug on.
    Most tails are sonic welded. I always used a hot knife....$30 from your decor store.
      locking because it's a duplicate with less posts.
      other thread:
      https://www.hidplanet.com/forums/for...ermarket-tails
