Philips DLS 25w, interchangable with D3S 35W?
  • Philips DLS 25w, interchangable with D3S 35W?
    Hi all
    Just took delivery of my car and was expecting it to have 25w D3S bulbs and thus upgrade them to 35w Philips Xtreme D3S bulbs.
    Upon opening it up, it seems they have 25w DLS Bulbs, the connections look similar except for a small tab which stops them from fitting.
    Can anyone confirm if D3S bulbs will work in place of the 25W DLS if I trim the connector to fit?
    Picture 1
    Picture 2
    Picture 3
    Picture 4
    Picture 5
    DLS? Not D5S or D8S?
    My retrofits
      You cant operate D1S or D3S at 25 watts, your ballasts will not provide enough power to run a 35 watt bulb, 28 to 30 watts is the minimum power for a D1, D3, D2 or D4 bulb.
      Looks like Philips has a new product not just the D5S with the ballast and igniter all integrated into one box. We dont even know if the focal point is in the same position as the 35 watt bulbs on your NEW DLS bulbs. The D5S has a much shorter glass bulb section with the focal point of light LCL of 18.0 compared to 27.1 on all the other HID bulbs.
        what car is this on?
        ________
        I MADE ME
          The "25W" refers to the ballast output, so throwing a D3S bulb will mean it'll run at 25W anyway, which isn't what you want.
            They came with a current Porsche Cayman, which all documentation say it "should" be D3S. Unless they have decided to change for some reason?
            I was wanting to change to change out the OEM ones for a brighter white bulb, can anyone identify what type these should be as DLS doesn't come up anywhere....
              Just spent some time working out my google fu and came up with nothing. These must be for the low power HIDs used in Europe to avoid auto-leveling requirements.
              50w Quads 85122+
              50w Fogs 4300k XB35
              20" E-Series
                Yes, I agree and they are also Hg free. They must be so new, not even an E code number on them. If the focal point is different you cant even replace them with other standard 35 watt bulbs. You would have to replace the projector assembly as well. Also the ballasts of course too.
                  I just did this myself. I bought the upgraded 35w ballasts from the PDLS headlights, trimmed the connector to fit the D3S bulb, and they work.
                  The issue is the hotspot is not at the center and a bit too low.
                  I did notice that when comparing the DLS to D3S, the length is the same, but the DLS necks down sooner at the top of the bulb.
                  Has anyone tried shimming the bulb to see if the pattern can be fixed?
                  I realize that a new projector would be the best option, but since this is HID already I'm not sure where to start.
                    A photo of the 2 bulbs side by side is worth 1000 words, please send a photo.
                      Here's the bulbs side by side. I was planning to make a "How To" thread on rennlist/planet 9 eventually. I got pics of everything.
                      DLS vs D3S
                        Focal point seems identical, maybe a photo of both labels and both input connects would also be helpful.
                          Turns out I figured it all out. The tab locations on the DLS vs D3S bulbs are different to deter you from a simple swap. See attached pics. I plan to do a full how-to soon.
                          First: The tab that you need to bend out of the way a bit.
                          Second: The tab location on the bulbs; resulting in WHY you need to bend that tab in #1.
                          Third: The outcome... Nice beam pattern.
                            So hotspot is fine?
                              Hotspot looks fine now.
