Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: LS430 Projectors without the reflector
    Jul 2005
    Brooklyn, NYC
    37
    I am in a dilema. I got a great deal on a pair of 05 LS430 headlights. Comes with bulbs and ballast. Did'nt realize they were so big. Now I've been reading about the projectors having a reflector bowl and all. MY question is, can I cut the bowls off and still be able to get decent output?
    These will be going in a 1999 Mitsubishi Galant.
    I will be starting my retro this weekend, so any help is appreciated.
    Jul 2005
    Brooklyn, NYC
    37
    No reply, damn
    Senior Member HID KING need4speed's Avatar
    Dec 2004
    Ontario, Canada!
    1,964
    you just wouldn't get as wide a beam without those reflectors.
    Jul 2005
    Brooklyn, NYC
    37
    Ok, cool. I was doing some measuring and my headlight is about 4 1/2 in and the projector is about 5 in. I willl have do some hacking, but I wont be cutting off the reflector.
    Aug 2005
    Miami, FL
    152
    kool Galant i helped my dad buy a 98 this weekend same color. i didnt know you could clear out the front trun sig, nice good luck on the retro.
    Senior Member HID MASTER JSMexUsa's Avatar
    Feb 2005
    2,740
    Quote Originally Posted by devgrp
    Do your best of trying to fit the whole projector, you should be able to trim the reflector part a little. Those are one of the best projectors out there, specially when light 5 lanes, the widest output. If you can't fit them I would just buy diferent projectors S2000 or TSX. Good luck.
    Senior Member HID Nut dsjr2006's Avatar
    Aug 2005
    Muskegon, MI
    644
    If I was going to do anything to the reflector I would only trim off a little from the bottom, but not completely remove it.
    DWizzle
    Jul 2005
    Brooklyn, NYC
    37
    Thanks for compliments guys. I wont cut off the reflector. I will try and trim it the best I can. I'm starting this project this weekend.
    Senior Member HID Nut mash835's Avatar
    594
    I suggest, to save your money, you don't alter the projector in any way. The LS430 projector works as a hole unit, if you cut/trim any part of it you will not get the bright/wide output which most people who buy this projector are looking for. So you can save little money if you sell it and buy another one such S2k or TSX.
    Jun 2005
    526
    You can’t trim or modify the LS430 projector shroud bowl bottom or you’ll lose the output that makes the LS430 unique. If you do, you’ll just have an expensive S2000 projector. You’ll also need roughly a 7 inch diameter to fit the entire LS430 shroud. It’s a perfect fit in my 2005 F150.
    Duke
  1. Reflector Cut-off
    By Scomp23 in forum General Discussion
    Last Post: November 13th, 2004, 04:50 PM
  2. scratched reflector housing
    By petah in forum General Discussion
    Last Post: November 10th, 2004, 06:33 PM
  3. Reflector HID Q&A: will Casper shields and D2R bulbs wor
    By Outkasted24 in forum General Discussion
    Last Post: October 14th, 2004, 11:58 PM
  4. Need Advice for H4 ('00 civic) reflector HID setup
    Last Post: October 8th, 2004, 08:22 AM
  5. 4100K from xenondepot.com 02 chevy venture reflector shield
    By pankaj2000 in forum Projector Retrofits
    Last Post: September 15th, 2004, 05:20 PM
