Thread: How to install Wiring harness on my HID's?
    Oct 2005
    13
    What I need to know is how do I install my H7 wiring harness when I have bosch ballasts? Here is a link to the wiring harness I got for my retrofit hid's, http://<a href="http://www.xenondepo...duct_id=50</a>
    Incase your wondering what kind of car I drive, a Tiburon, with soon to be full tuscani conversion. Any help is greatly appreciated.
    Oct 2005
    Mississauga, Ontario.
    809
    Do not buy there wire harness. It's crap. The wireing is too small.. 18 gauge going into the relay and comeing out. You need 12 going into the relay or even 8 and 10 or 12 after the relay.
    I made the mistake of buying from them. It's crap and a rip off. They cant run a bussiness there communication skills suck big time.
    Dave.
    GMC Sierra 2500 6.0L. TSX mod. 2011 F350 in progress..
    Oct 2005
    13
    OK. But you still didn't answer my question. Somebody please help. I can't keep changing the fuse ever time I turn on my lights. Help!
    25
    as of now, how do u have it installed? it looks like there is no instruction on their webpage as to how. but, if u were to do what everyone else is doing...connection the the positive termial ring to the positive battery and grounding the negative termail either to the negative battery or on a clean surface area. plug ur OEM female socket to the male socket of their harness. and, finally, plug in ur connector to ur ballast. you should be good to go. let me know if this help.
    Senior Member HID Rookie camarok's Avatar
    Brown Deer Wisconsin
    419
    Quote Originally Posted by Turambar
    Assuming that you are running off of your stock headlight harness seem like, not good, but you want to fix this... ok... so.
    http://hidplanet.com/forums/viewtopic.php?t=3237
    and this one
    http://hidplanet.com/forums/viewtopic.php?t=6612
    this one too
    http://hidplanet.com/forums/viewtopi...ghlight=pinout
    search button is your friend, along with HIDplanet UNIVERSITY!
    if you have some knowledge in wiring, try making one yourself! Actually not too hard to do, looks confusing but not that bad.
    KEVIN
    CDV Free, 545i Shifter and ///M Weighted Shift knob.
  1. I need a 9007 bi-xenon wiring harness
    By Civicsilover43 in forum Wiring Questions
    Last Post: September 18th, 2006, 10:25 AM
  2. Need pics of 2002 and up Dodge Ram HID install
    By theg12eato17e in forum General Discussion
    Last Post: August 29th, 2006, 01:18 PM
  3. Relay wiring harness
    By Mart in forum Wiring Questions
    Last Post: October 7th, 2004, 12:19 AM
  4. Wiring harness has problems.
    Last Post: September 25th, 2004, 07:46 PM
  5. 9007 wiring harness
    Last Post: September 9th, 2004, 09:15 AM
