Results 1 to 3 of 3
Thread: D2S & D2R HID Bulbs: Are they interchangeable?
    Jul 2005
    Fresno, CA
    8
    Are D2S bulbs interchangeable with D2R bulbs? I have a reflector type headlamp so I use the D2R bulb, the one with the metallic strip along one edge. I have read that the D2S bulb emits slightly more light. Has anyone tried this before? And since the D2R has the metallic strip to combat the glare how would a D2S which is used in projector-type assemblies work? Anyone who has any experience or more knowledge than me please let me know.
    May 2005
    Northern California
    598
    Re: D2S & D2R HID Bulbs: Are they interchangeable?
    Quote Originally Posted by chrisr
    You would have to add a notch to the bulb's base. However, do not put a D2S bulb in a reflector housing. It will cause glare and blind oncoming traffic. If you want more output get a higher wattage ballast or retrofit projectors.
    LED Brake Lights | TSX Retro
    Mar 2005
    314
    ^^what he said
    if you really wanted to test out the d2s output and are sure you don't want to go back, you could always carefully take off the magnetic shield from your d2r bulbs with a razor blade and some alcohol
  1. OSRAM BULBS = PHILIPS BULBS ?
    By rizzlehd in forum General Discussion
    Last Post: April 26th, 2006, 01:46 PM
  2. Xenon bulbs and foglight bulbs
    By trp647 in forum General Discussion
    Last Post: March 20th, 2006, 10:24 PM
  3. Replies: 2
    Last Post: December 22nd, 2004, 08:20 PM
  4. Interchangeable parts?
    By itsmike in forum General Discussion
    Last Post: December 13th, 2004, 06:58 AM
  5. New bulbs vs colorshifted bulbs (4100k)
    By haknslash in forum Projector Retrofits
    Last Post: November 18th, 2004, 09:43 PM
