Results 1 to 10 of 16
Thread: 2014 Jeep Grand Cherokee HID LED Headlights
    Successfully converted a friend of mines limited to the new heads that come on the Overlands. Here's the video of the operation.
    http://youtu.be/gXqMh9A_es0
    Senior Member HID FANATIC Sean Lezner's Avatar
    Feb 2012
    In A Wendy's Induced Coma
    5,722
    As in a retrofit or just a simple swap in and out? As you and your video don't elaborate very well.
    GMC Sierra: RX350BX (EU) | E55-R | OEM Lens | Denso Slim | Osram 66240 CBI | 5K LED Interior Lighting
    Senior Member HID Nut nubnubz3215's Avatar
    Jul 2012
    Central Jersey
    762
    I think he's just showing the function of a harness that will allow the hid headlights to work on a halogen car thingy..
    Senior Member HID MASTER mdufficy's Avatar
    Oct 2011
    3,739
    I think swap and he made his own harness
    BrokenVisaCard
    Guest
    I'm confused. He made a clone to work the same under a single unit??
    Quote Originally Posted by Sean Lezner View Post
    This is a video showing the operation of the headlights using the harness to convert any non-hid car to the oem hid/led heads you see in the vid.
    Feb 2012
    5,722
    Quote Originally Posted by tuxedoblack11 View Post
    I did indeed view your video, but the description (or lack thereof) of whatever you did was rather ambiguous. I don't too many users on here that own the newer Jeeps and would subsequently be thrilled by this mod so you may have better luck posting it on a dedicated Jeep forum.
    Yeah I know but i thought id share the idea with all of you and have posted this in multiple jeep forums already. Just thought since this is an HID Site that people would like to see there are options out there. Basically all the harness consists of is a morimoto h13 bixenon harness with oem inputs and outputs to fit the application with the exception of the switchback controls to turn off the DRL's.
    Feb 2012
    5,722
    Not bad at all. I'm sure it will be a nice go-to option for Jeep owners.
    Oct 2011
    3,739
    Now what would be even cooler would be retrofitting in those lights with a good projector
