Results 1 to 3 of 3
Thread: RX330
    Apr 2012
    25
    RX330
    Guy i have a pair of morimoto d2s projectors that have the tabs broken i recently bought a pair of rx330 i was wondering if i can swap the clear lens from the morimoto's to the rx's and how they will perform?
    Senior Member HID Recruit Iv4n2402's Avatar
    Jan 2012
    Serbia
    227
    Measure the distance between the flat piece of the lens and the cutoff shield on both projectors.
    If it's the same - it could work.
    Senior Member HID Learner blackcam09's Avatar
    Mar 2010
    PA
    98
    if the morimoto's lens are 2.5" it should work on the RX330.
    Headlight retrofit (low beams):
    RX330 Projectors with blue painted stock shields (Limiter removed)
    TSX-R Clear lenses
    Matsushita Gen V Ballasts
    Osram 66240CBI D2S (5000K) Bulbs
    High beams: Mtec super white (4350k) bulbs
    Blackout housings with stock chrome rings
    Morimoto relay harness
