View Poll Results: pick winner
Voters
48. You may not vote on this poll
  • joon joon - civic si
    18 37.50%
  • offroadkarter - mercury marauder
    7 14.58%
  • RaZVaN - daewoo
    1 2.08%
  • cykaaro - jeep grand cherokee
    2 4.17%
  • bilinvic - ford f150 platinum
    5 10.42%
  • soundman98 - mitsu eclipse
    4 8.33%
  • Viper238 - ford f150 xlt
    1 2.08%
  • silveraltima44 - nissan altima
    1 2.08%
  • kasso - nissan maxima
    1 2.08%
  • blackcam09 - toyota camry
    8 16.67%
Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: March ROTM Voting
  1. #1
    Administrator HID FANATIC@#$! gearbox's Avatar
    Join Date
    Sep 2006
    Location
    NV
    Posts
    19,233
  2. #2
    Join Date
    Sep 2006
    Location
    NV
    Posts
    19,233
    very tough choice this month. lots of good entries
  3. #3
    Senior Member Bright Halogen Tom550's Avatar
    Join Date
    Dec 2011
    Location
    Albuquerque, NM
    Posts
    221
    I really couldn't decide. But si did a good job.
  4. #4
    Join Date
    Jan 2011
    Location
    Calgary
    Posts
    250
    Might as well give a good critique of all the entries
    Civic SI
    Good - double retrofit, good choices on all projectors
    Bad - Been done before, no output shots except the one glare shot
    Mercury Marauder
    Good - double retrofit again, looks like an old grandpa for some reason but very appealing
    Bad - horizontal aim may be off a smidge, would like to see a write up or something
    Daewoo
    Good - unique car, looks very clean
    Bad - all pictures the same
    Jeep Cherokee
    Good - Quad retrofit, looks good
    Bad - a bit too much going on with lighting in the front
    F150
    Good - Canadian haha, Very very clean (almost professionally done clean), good color choices
    Bad - Could have filled out the big headlight a little bit more
    Mitsubishi Eclipse
    Good - Looks really clean, DIY included (big plus)
    Bad - Could have used a bit better projector
    F150
    Good - Looks good!
    Bad - Very small projectors for a big light
    Nissan Altima
    Good - Looks like a small area to work with, so good projector placement
    Bad - A bit too much going on in the light areas with all the LEDs
    Nissan Maxima
    Good - Good cutoff
    Bad - Not very many or good quality pictures to judge from
    Toyota Camry
    Good - very OEM looking, great cutoff
    Bad - You took the second pic a bit too low or high because the colors are slightly different. Thats my only critique, your photography skills :P
    Either way nobody will know who i voted for :P
  5. #5
    Senior Member Baby Halogen blackcam09's Avatar
    Join Date
    Mar 2010
    Location
    PA
    Posts
    107
    Quote Originally Posted by MechEngg View Post
    Toyota Camry
    Lmao thanks bro, I'm going for the OEM look when I modify my car. Haha yeah I took it too low so you can see the color flicker effect. Plus I took it with my phone a samsung s2 with a 8 megapixel camera. I guess I need to step up my photography skill!
    Headlight retrofit (low beams):
    RX330 Projectors with blue painted stock shields (Limiter removed)
    TSX-R Clear lenses
    Matsushita Gen V Ballasts
    Osram 66240CBI D2S (5000K) Bulbs
    High beams: Mtec super white (4350k) bulbs
    Blackout housings with stock chrome rings
    Morimoto relay harness
  6. #6
    Senior Member HID KING offroadkarter's Avatar
    Join Date
    Oct 2010
    Location
    NJ
    Posts
    1,325
    I think joon joon has this one wrapped up lol
    Mercury Marauder
    I have a defective bulb in the drivers side, so that isn't helping any. I built my housings with horizontal and vertical adjustment, so even though they are rotationally correct, if I ever have to fix it, I can
    http://www.hidplanet.com/forums/show...R-1.1-Retrofit
    1996 Ford Bronco - Morimoto Gen 3 H1 / 3Five Ballasts / Morimoto 5000K H1 / Generic 9007 harness
    2004 Mercury Marauder - Morimoto FX-R 1.1 / 3Five Ballasts / Osram Xenarc 66240 CBI / TRS HD 9007 harness
    Love poverty beams? Then do I have a message for you....
    Quote Originally Posted by BrokenVisaCard View Post
  7. #7
    Join Date
    Sep 2006
    Location
    NV
    Posts
    19,233
    you never know, usually 50-60 voters so we are only half way
  8. #8
    Join Date
    Oct 2010
    Location
    NJ
    Posts
    1,325
    I told you joon joon has this one wrapped up, I've been in enough forum "of the months" to know when someone is gonna do a clean sweep lol
  9. #9
    Senior Member HID Nut
    Join Date
    Jan 2011
    Location
    State college, PA
    Posts
    669
    where's the entry thread at? i thought you guys used to put a link for it in the first post. not a link to the same thread i'm viewing lol
  10. #10
    Join Date
    Sep 2006
    Location
    NV
    Posts
    19,233
    i thought it would be easier to put both links (voting and submissions) on the buzz page. but here it is.http://www.hidplanet.com/forums/show...st-Submissions
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
