Results 1 to 10 of 11
Thread: Rx330 +TSX-R lens install
    Apr 2011
    las vegas
    85
    What's the best way to install this lens into the projector. Since the stock lens is a little larger in diameter it slides around and isn't secured tightly by the lens holder.
    Thanks
    Senior Member HID KING Genes1s's Avatar
    Oct 2010
    Vancouver, WA
    1,532
    Take a 16-18 gauge insulated copper wire and put it between the lens dia and the inside dia of the lens holder. Perfect Fit, no wiggel whatsover. Well....this is my method, others might have different ways u know...
    FEEDBACK THREAD
    00-03 Nissan Maxima HID Retrofit
    6th gen AV6 FX35 Retrofit
    Chassis and Suspension
    2000 Sunlit Sand Maxima SE 5Spd.1997 Techno Violet E36 M3 Coupe 5Spd.
    Apr 2011
    las vegas
    85
    Thanks for the tip. Did you use any spacers?
    Sep 2011
    359
    If you purchased the TSX-R lens from TRS, you should have the rubber washers to center and retain the lens on the RX330.
    green spacer + TSX-R lens + rubber washer + metal lens retainer.
    Oct 2010
    Vancouver, WA
    1,532
    Quote Originally Posted by stoney05 View Post
    No more additional spacer for me, I even took the green spacer out since I fab new curved shield.
    FEEDBACK THREAD
    Apr 2011
    las vegas
    85
    Digitalpro:
    I ordered the lenses with some TSX projectors so I didnt get a rubber ring. Know how much they charge?
    MSU2000:
    How long did it take you to make that custom shield ? I'm actually in the process now.
    Sep 2011
    359
    Quote Originally Posted by MSU2000 View Post
    stoney05,
    ^ Just use MSU2000's option, should work just fine.
    Oct 2010
    Vancouver, WA
    1,532
    Digitalpro:
    MSU2000:
    That specific one took 10 minutes, but I practiced alot....I mean probably few dozen shields made untill I'm comfortable with the technique and have the right tools and method to do it. Just practice, get your self enough material and start cutting and tweaking. Making shield is easy, trying to to get the cut off right isn't
    FEEDBACK THREAD
    did u do custom shields to help with that weird little bowl/wave?
    I been working with stupidpig to make custom shields
    Here beta test 1. I need to play with the spacing of the shield also. I think I spaced it too much.
    I still have 2 more different shields to work with
    Got Retrofit? Owner HID MASTER TRSMatt's Avatar
    Aug 2010
    Atlanta, GA
    3,606
    Also, are you doing the swap on AFS or non AFS projectors?
    2013 Lexus GS350 F Sport : Skipper Designs Front Lip : Rotiform BLQ Concave : Michelin PSS : Brembo GT 380mm : RSR Suspension : GS350/STi-R Bi-xenon
    * For any inquiries please e-mail Matt@TheRetrofitSource.com, PM's = not a good way to reach me*
