Results 1 to 10 of 14
Thread: How to clean pitted glass headlights
    Sep 2011
    Torrance, CA ( Los Angeles area )
    126
    As stated in the title. Need a easy and cheap way that might clean up some 20+ year old pitted headlights. This is my biggest draw back on my retro.
    photos of my lights. Thanks in advance!
    !​needs a retro!
    Feb 2011
    312
    Something like this: http://www.eastwood.com/glass-polish...ches-5658.html
    Can also make your own from cerium oxide.
    Could also replace the headlights as they're still made.
    Senior Member HID MASTER PedroDaGr8's Avatar
    Feb 2007
    San Diego, CA
    2,657
    Bingo. Cerium Oxide powder plus a lot of elbow grease will polish the glass properly. As I have warned others using this stuff. Cerium Oxide has very very trace amounts of radioactive thorium. So there is a slightly above background radioactivity with this material. I wouldn't keep the tub in your pants next to the boys but it is far from posing any sort of health issue. I don't have any stats but my guess is that the radioactivity would be similar to a concrete block wall (which are also slightly radioactive due to the presence of potassium-40).
    Aug 2011
    Kansas City
    87
    ^^ lol.... $60 to restore headlights?
    http://www.gpona.com/forums/do-it-yo...on-t18468.html
    Sep 2011
    126
    thanks guys, im going to try car polish first then if i cant get it good ima buy that stuff.
    !​needs a retro!
    Senior Member HID KING paleryeder's Avatar
    Aug 2010
    Antelope Valley, CA
    1,981
    Quote Originally Posted by aksc View Post
    That Eastwood link is for glass, the one you posted is a shadetree way to do plastic lenses and will chip and look like garbage in no time. His BMW lenses are made of glass.
    You can buy the cerium oxide on Ebay in bulk for under $15 then you just need some type of drill motor and buff. It's very hard to do without some kind of power tool. If they're pitted deep then you need some diamond wheels used for granite counter tops, they come in many grits and you just work your way down.
    Car polish is a waste of time, it won't cut the glass it will only fill the pits with white powder then they'll really look bad.
    Feb 2011
    312
    Not only is cerium oxide slightly radioactive, polishing glass produces silica dust which is quite bad for your health as well. Even though you should keep it wet, a respirator is highly recommended.
    Hella and Bosche both make those headlights new though. Not sure on the price as I dunno the year of your car (not great with BMW's to be honest)
    Aug 2010
    Antelope Valley, CA
    1,981
    You have to use it wet I don't know how you'd even use it dry and the chances of a health problem is much higher just by driving your car down the street compaired to doing one set of lenses. It's the same as using any type of solvent, 95% of the time people don't were gloves but when it gets into your skin and lungs it can cause health problems too. Do you wear a respirator when using your dremel or putting gas in your car or everytime you solder?
    I've been around gemologist my entire life doing lapidary work with all grits of cerium oxide and many other like compounds and never once seen one with a respirator on. My uncle is 95 and has been doing this type of work since he was in his teens.
    If it makes you feel better then by all means wear gloves, goggles, respirator and a clean room, just make sure you do the same everytime you use any polishing compound or are cleaning your bathroom. If you really want something to worry about check out the air quaility studies on driving down the freeway. Which by the way is something many people do everyday of their life with no respirator.
    Feb 2011
    312
    True, but as I have the respirator sitting around anyway, it wouldn't be an issue for me Any well stocked garage should have one.
    Sep 2011
    126
    Quote Originally Posted by Poodles View Post
    87-92 32i (e30) euro bosch smileys
    !​needs a retro!
