Results 1 to 9 of 9
Thread: D2S vs D2R Philips light bulb
    New Member HID Newbie dyakovly's Avatar
    Jul 2011
    47274
    19
    Question D2S vs D2R Philips light bulb
    What is difference between Philips 85122 D2S and Philips 85126 D2R?
    Will D2R fit in D2S light housing and perform as same D2S? Thanks,
    Jul 2007
    122
    You can cut a notch to make it fit...but D2R is for reflector, thus have a shield..blocking out light so for projector it's best to use D2S.
    Moderator HID KING joon joon's Avatar
    Oct 2008
    Los Angeles, California, United States
    1,876
    yes you can fit the d2r in d2s projectors by notching the base.. the output will decrease with the d2r though
    Jul 2011
    47274
    19
    Thank you, just canceled my purchse for D2R and bought the right one, didn't pay attention for R and S marks.
    Brightening Up Your Day LORD XENON gold94corolla's Avatar
    Nov 2007
    Columbia, Maryland
    19,536
    and similarly, you can use the D2S bulbs in a D2R reflector with the proper notching (I did lol).
    Junior Member HID Newbie Nileo2005's Avatar
    Feb 2011
    Toledo Ohio
    55
    Quote Originally Posted by gold94corolla View Post
    Won't that cause glare?
    Senior Member HID KING kcg795's Avatar
    Feb 2011
    1,050
    I think the Priuses with the D2R reflectors are blinding enough as it is. Sometimes I wonder if Prius owners are swapping in D2S bulbs.
    17,140
    nah they just suck. looks worse than pnp kit on the wall like a fuzz and small hotspot in the middle.
    Nov 2007
    Columbia, Maryland
    19,536
    Quote Originally Posted by Nileo2005 View Post
    well since it is not projectors, there is a normal amount of glare with either bulb. I found that the reflector was designed to point the light where it needed to go, and the unblocked light didn't make a difference (as the HID is not brighter).
    Here's a pic.... an old d2r 4300k bulb on the left, and a new 5000K d2s on the right (keep in mind that the new bulb should be brighter anyway since it is new)
