Page 1 of 7 1234567 LastLast
Results 1 to 10 of 66
Thread: Shroud Paint
    Senior Member HID Nut TrakTuned's Avatar
    Mar 2011
    Pnp Central, So Cal
    564
    Shroud Paint
    I am finally getting my retro rolling and want some info before gathering all my supplies!
    So questions questions.......I have some e55's and I need shrouds to keep them from leaking light all over the place. I will be using some apollos and I want to color match them to my car (silver).
    • Will I need to use high heat paint on my shrouds? on the outside not inside where light hits them.
    • OR can I use standard spray paint and bake them...?
    I see a lot of people with painted shrouds and i cant imagine that all the various colors are high heat paint...
    Thanks!
    Jan 2010
    In my LED lab
    1,016
    I used OEM body matched PPG paint (white) on my first retro. Its been almost a year and they look just as good as day 1 still.
    Senior Member HID Guru 0212353's Avatar
    Jul 2010
    856
    standard auto paint works just fine.
    Mar 2011
    Pnp Central, So Cal
    564
    Nice!! widen my options substantially... Do I need to cure them through any process, or just paint and install?
    Moderator HID FANATIC JL-KA's Avatar
    Jan 2010
    Peoria, IL
    5,818
    Let them cure full before installing.
    In the works: LS460 | SVS | Morimoto 5Five | Hella 60mm | Toshiba HIR
    May 2011
    Louisville KY
    42
    Whats the point of painting them? I thought you couldn't see the shrouds anyway?
    Lifes a laughand death is the joke.
    Moderator HID FANATIC soundman98's Avatar
    Apr 2010
    i'm only sane on days that end in z
    7,892
    ^the shrouds are to cover up the projector assembly, and add a little style...
    just be sure to dechrome them before painting-- my gatling guns took a good 3-4 hours in oven cleaner to get dechromed(the oven cleaner method means you don't need to sand the texture out of the shroud)..
    i used the krylon plastic paint, and it came out really good(the red stripe is standard rattlecan-red though.)
    Quote Originally Posted by John Lennon
    The time you enjoy wasting, is not wasted time.
    2001 Eclipse led conversion, high power led reverse light conversion (dead), led reverse light-revision 2 done!
    note to self, winter sucks
    my 2014 brz
    Jun 2011
    NE Ohio
    567
    I just litely scuff the chrome with 1000 grit sp....wet of course and after a cleaning...use duplicolor adhesion promoter and then I was using duplicolor perfect match...but the weather is giving me a no on that one so now I am using rustoleum wheel paint...goes on very smooth with no orange peel. Only 4 colors available though
    Jul 2010
    856
    Quote Originally Posted by soundman98 View Post
    that is so weird.......I just did a set with a red ring on 'em too!
    Apr 2010
    7,892
    lol... but mine were painted as a hid-correct copy of my first set of aftermarket lights! (i did these about 2-3 years ago):
    it looks like you ground down the outside to better fit the projector--i'm guessing a fx-r? any details on how you did that?
    though, on a red vehicle, i think that a accent ring like this is the perfect way to accent a dark housing without going tacky.. i had considered painting all the 'ridges' red as well..
    my 2014 brz
