Page 1 of 14 1234567891011 ... LastLast
Results 1 to 10 of 139
    Burn'in Down Tha House HID SCHOLAR soundman98's Avatar
    Apr 2010
    i'm only sane on days that end in z
    10,826
    high power led reverse lamp build (Rev 1)
    this is my continuation of this thread. i figured making a new thread for my specific design would be better then crapping all over blurred talons thread...
    to recap:
    i had tossed the idea around in my head for a month or two before blurred talon started the thread, but after his thread, the ball started rolling...
    in his thread, i posted some output shots of a cree xp-g r5 flashlight, good for about 350 lumens to compare to my current filament reverse lamps.
    i wasn't happy with the overall light output, so i decided to order some cree xm-l's to be sure that i would have enough illumination.
    to date, i have ordered 6 XM-L T6 high power led's, and 6 3000mA constant-current drivers.
    i intend to use 4 total, or 2 per side.
    for reference, a picture of the back of my eclipse:
    measurements:
    the reverse lamp portion of the lower housings is roughly 6" wide.
    the area behind the reverse lamp has about 4" on the outside of the opening and 5" on the inside of the opening of clearance between the metal body-- measured off the front of the reverse lamp housing.
    there is a crashbar about 2-3" below the reverse lamp housing, otherwise, the entire bumper area is pretty clear of obstacles.
    and also for reference, the housings that i intend to use for the retro:
    as i talked about in the other thread, these led's put out a lot of heat. with the led's mounted on a 6"x1"x1" square aluminum tube, they had a heat rise of 5 deg per min in a 5 min run time.
    admittedly, a short length of raw square tubing is a poor heat sink, but has taught me a very good lesson that serious heat sinking is required for led's like this..
    problem:
    • average backup time is about 5-10 minutes-- about 200ft of alley, 30-40 seconds for garage door to open, and time to back into garage.
    assembly issues to overcome:
    • must run for 10 minutes, want to shoot for 20 min run-time.
    • must stay below 100 deg F
    • getting the 2 led boards+ heatsink assembly to look good under the clear lens.
    assembly goals:
    • cost should be below $50 per side for heatsink components(i'm not going to complain if it hits 55-60).
    • doesn't matter if design is active or passive.
    • passive is the preferred method due to the location getting exposed to some dirt/water.
    • would prefer small-enough components to allow for a mostly-PNP design that would not require bumper removal.
    that about sums up what i am trying to accomplish.
    right now, i am looking at computer processor heatsinks, as many processors put out about the same amount of heat. though mounting the heatsink, and dust/water in a cooling fan is a little worrisome..
    any ideas anyone has would be greatly appreciated.
    Senior Member HID Rookie JaySilver's Avatar
    Aug 2010
    Florida.
    327
    I don't know if its possible but, would you try water cooling instead of air cooling? Like what they do in computers?
    Silver 01 Lexus Gs300.
    Apr 2010
    10,826
    i briefly considered it, but after recently talking about it in a unrelated forum, the minimal performance gains over standard heatsink cooling are usually not worthwhile in-car after considering the extra setup time and maintenance it takes. (link)
    i will def. keep it in mind(why can't there be a easy solution to every problem!?)-- running extra tubing in/under the car might allow me to have enough fluid to get the run times i need without trying to actually cool everything--er, i mean, have enough fluid in the lines so by the time the fluid is hot, the car will be parked/finished backing up for a while so the lines can cool down again--so i wouldn't need a radiator to try to get rid of the heat.. the bonus is that everything would be sealed, so water/dirt isn't a problem, the minus is the extra maintenance, and driving the pump to circulate the fluid.. but the bragging rights of having water-cooled reverse lights...
    whereas a heatsink setup would require me to displace any heat the led's create almost as fast as the led's can create it..
    suffice it to say that i am still flip-flopping on the method, but would def prefer a heatsink design for the low-er maintenance...
    Senior Member HID KING Raptor05121's Avatar
    Nov 2010
    Live Oak, Florida
    1,039
    This is what I'm looking at:
    http://www.luxeonstar.com/High-Effic...-LED-s/195.htm
    They have 19mm square heat sinks and I'm going to use 25mm for more space. Just mount the LED to it, and cut a 19mm (or 25mm) square, slide it in, and epoxy in place.
    There are two kinds of light - the glow that illuminates, and the glare that obscures. -James Thurber
    1998 Ford F-150 | FX-R 2.1 / Philips 85122XV C1 / Matsushita Gen5 | Philips LumiLEDs | Plasmaglow Fire & Ice
    Senior Member HID Guru Mike S's Avatar
    Nov 2010
    848
    I didn't know you were planning to drive these at 3A each. That's a lot of light!
    Could you cut out the back of the housing to accept a large computer heat sink? I haven't been able to drive my XM-L's harder than 1A, so I can't say for sure if it would be adequate. It might be worth a shot.
    May 2010
    Oceanside, 92056
    408
    Are you trying to drive 2 emitters next each other, or some spacing between?
    3A drive each will be about 20W of power you need to deal with if you use emitters next each other.
    XM-L thermal resistance is 2.5C/W to PN junction to thermal patch contact.
    Assuming avarage alluminium star board thermal resistance about 1.5C/W
    Thermal paste about 0.1C/W
    XM-L max junction temp is 150C, add 20% mergine to aim 120C target temp.
    Ambient temp set as 25C
    (120-25)/20=4.75C/W
    4.75C/W-(2.5+1.5+0.1)C/W=0.65C/W
    0.65C/W passive heatsink gonna be massive I assume.
    When 2 emitters are seperate, can consider two different heat source,
    each one will be about
    (120C-25C)/10W=9.5C/W
    9.5C/W-(2.5+1.5+0.1)C/W=5.4C/W
    depend on heatsink design, location, angle you set, 5.4C/W can be rather compact.
    when space is available, heatsink fin want to be not too dense so it won't get extra air flow resistance.
    layout to enchance vertical air flow. Vertical longer each fin is better thermal capacity.
    when air flow expected, heatsink capacity can be smaller.
    So, now, if 2 emitter need to be sperate, good looking design in clear housing can be difficult I think.
    Will one emitter won't be enough? or half of driving rate at 1500mA?
    If driven at 1500mA, typ Vf is 3.1V, 4.65W each emitter and 9.3W total
    This case, your target heatsink capacity is about 6.11C/W
    and can expect max 520lm x 2 =1040lm
    or one emitter at full drive
    target heatsink capacityof 5.4C/W for about 10W power
    expect 910 lm max
    About 5C/W(ambient at 25C caluclation) passive heatsinking seems to be doable.
    Senior Member HID Nut corvettecrazy's Avatar
    Sep 2005
    Northeast
    594
    Quote Originally Posted by upashi View Post
    And since he probably doesn't live in an area that is 25C and less year round, what happens when it is 45C outside?
    Personally, I think your run time estimates are kind of crazy. If you take 5 minutes back up time. Take out a minute for the garage door. Then you go 220 ft in 4 minutes. Which is .91 ft/second. (1mph =1.46 ft/s) Can you actually get a car to go that slow?
    Regardless, I would get the largest thermal mass you can and run with it. If you back up your alley twice a day, everyday, for 4 years and it takes you 20 minutes each time then the total run time of the LED's is: 58,400 minutes= 978 hours. The XM-L has gone though significant LM-80 testing which states that it can maintain over 90% lumen maintenance at 1500mA over the period of 6000 hours. Your 1000 hours of run time at 3000mA is peanuts.
    Get a chunk of aluminum with fins on it and move on with life. I'd be more worried about the plastic housing being able to handle the heat than the LED.
    Apr 2010
    10,826
    Quote Originally Posted by Raptor05121 View Post
    thanks for the link! that was exactly what i was looking for earlier. bookmarked.
    Quote Originally Posted by Mike S View Post
    yes, i was planning on cutting the rear of the housing to accommodate the heatsink.
    they are about 4-5" apart, but in the tests the led's were thermally connected:
    this is my earlier picture, before i screwed the led's down to the aluminum:
    (120-25)/20=4.75C/W
    expect 910 lm max
    thanks for doing the calculations! that pretty much solves it.
    i will use a single heatsink per led. for some reason, i was thinking it was better to thermally combine them....
    i just remembered i have some old cpu heatsinks in my basement-- i am going to attach led to one, and see how well it works-- it is a little tougher when i don't know the exact c/w of the ones i have..
    after thinking about it today, i am going to focus on using a heatsink that should hold up while being passively-cooled, but will add some fans to to aid in keeping the temp down--at least until the fans die from the tough area.
    thanks for the advice!
    Nov 2010
    Live Oak, Florida
    1,039
    bumping for a good read
    Senior Member HID MASTER azdave's Avatar
    Arizona
    3,214
    Are you sure you aren't building LED headlights?
