Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Xenon bulbs hotter then halogen?
    Senior Member HID Rookie kikkegek's Avatar
    Sep 2010
    The Hague, Netherlands
    440
    hi guys,
    I have a question on xenon vs halogen bulbs.
    I have used xenon bulbs in my H4 housings, but wasnt satisfied with the output and blinding other drivers.
    I then changed from these xenon to regular cheap H4 halogen bulbs.
    with the halogen bulbs in the housing the lens gets so hot within minutes, that you can not touch the lens anymore without hurting your hands. is that normal?
    I was wondering.
    My halogen are 55W and my H4 Xenon bulbs are only 35W. Do the xenon bulbs thus produce less heat and more light?
    I bought some new housings and I am using my old housings for my retro with Morimoto Moni's, but dont want burn up the new housings again within one year in the mean time.
    some help with these bulbs would be nice.
    Senior Member HID Nut MAD's Avatar
    Jun 2009
    Melbourne, Australia
    635
    What causes your lenses to get hot with halogen is infrared radiation. HID bulbs dont emit infrared radiation so they never really warm the lens up much.
    That can be a problem if you're in a snowy/icy area, that's one of the reasons for high pressure washers.
    What they can emit though is high levels of UV radiation. But if you stick to OEM or Morimoto bulbs you'll be right.
    HID lighting systems are much more efficient than halogen, I dont have the figures, but halogen loses a lot of energy to heat instead of light.
    Sep 2010
    440
    cool! thanks for the info!
    for now, until my retro is done, I'll put the bi-xenon bulbs in my headlight.
    with these bulbs for now!
    Attached Images Attached Images
    Jun 2009
    635
    Please don't. Please just leave the halogens in there until you're done.
    Sep 2010
    440
    why? the glare aint to bad. see picture below. top is halogen and bottom is bi-xenon bulb
    Apr 2011
    bay area, california
    92
    but it's a lifted truck, right?
    May 2010
    United States
    343
    I can see a lot of light above the hotspot. It is intensified by more than 2 times when using HID. Lifted trucks are higher, and the light will shine right into other cars mirrors.
    2008 Toyota Camry LE I4
    S2K Retrofit Headlight - Osram 66240SVS
    TRD 18 Wheel, Navigation system
    LED-heat-fold Turn Signal Side Mirror w/ JDM Switch
    OEM fog light, integrating to Turn Signal Switch
    Moderator HID MASTER Adam's Avatar
    Dec 2010
    Edmonton AB
    3,209
    I can verify that even a 55w HID bulb is very cool compared to halogen. If I have my bix high on and my halogen high on, after ten minutes the lens is quite hot on the halogen side and barely warm on the HID side. Huge difference
    LOL so much glare, the entire wall is illuminated
