Results 1 to 10 of 20
Thread: Cleaning Inside of Headlight Lens.
    Yeah what the title says, what can i use to clean the inside of the headlight lens? Since i heard that the inside is more sensitive than the outside. Thanks.
    May 2008
    39
    I'd also like to know! Is there something to be used for that??
    JP
    RX330 non-afs - E30 Clear Lens under construction!
    Senior Member HID MASTER Blurred Talon's Avatar
    Jan 2008
    Home - Newfoundland Work - Alberta
    2,545
    Compressed air, if you wipe it you will scratch it.
    Personally when I pull a lens off I seal up with plastic wrap and bubble wrap. Keeps everything out.
    Professional Retrofitter HID MASTER
    Oakland, NJ
    2,893
    A very light non abrasive soapy solution, once all debris is out, wipe it with a paper towel gently, and then rinse with distilled water. We then get all the water out with compressed air, but if you don't have access to compressed air, you can spot clean with a fresh quality micro fiber.
    You can scratch the lenses if you catch any debris inside.
    Senior Member HID Learner Moo's Avatar
    May 2011
    193
    Thanks LW - good advice.
    I'd advise against paper towels though; detailers will tell you that thay can contain microscopic bits of metal, as most brands are from recycled stock. Also the paper cellulose fibers can be rather sharp & harsh. Hence - the potential is there to scratch.
    A fresh, High-quality MF towel is best, if you need to touch it with anything, once washed out. Like car finishes, the less you need to physically touch it, the better.
    Cheers
    Bubba
    Thanks for the reply everyone. I'll try the MF towel. =)
    Apr 2011
    80
    yea, i scratched the inside of my lenses up just enough for me to notice personally and it bugs the crapp outta me. Say NO to paper towels!!!
    2003 silverado (Click Here to see the retrofit)
    QUAD MH1's with JVX mods in OE style headlamps (um.. yes they fit!)
    XB35 5000K
    3Five ballasts
    Quad Off Road 130W halogen spots (in sig)
    Two 55W yellow Fogs
    1999 Tahoe
    OEM headlamps....for now...
    Senior Member HID KING sbdrumr's Avatar
    Santa Barbara
    1,253
    paper towel?
    christ the cheap ones are like 320 sandpaper
    I would avoid making contact at all....compressed air and hope for the best.
    I've seen an RX330 get totalled from cleaning
    Senior Member HID Learner DJLeonardo's Avatar
    Dec 2010
    Amsterdam, Holland, Europe
    118
    When I have the lenses out (like I do that on a daily basis, not) I have rinsed them with tap water and a little mild detergent you hand wash your dishes with (not dishwasher tabs obviously)
    When I clean them from the inside when still in the prjojector I use an old but clean piece of t-shirt (the old ones are usually very soft right?) taped around a screwdriver so I can stick it inside the reflector. I did that a few times and no scratches at all. Just make sure you don't press too hard just a tiny little bit is enough to wipe it. It's more llike stroking.
    Junior Member HID Newbie Rottyfan's Avatar
    Jun 2010
    63
    When I cleaned the inside of my headlights I used a dishwashing sponge and lots of dishwashing soap and water. It still left fine scratches on the inside of the lenses. Had I known then what I know now, I would have just rinsed with water and a final rinse with distilled water as has been suggested.
    I think that eventually I'll get a new set of lenses from an aftermarket set of headlights. Sucks that you need to buy whole headlights just for one part.
