Results 1 to 9 of 9
Thread: Interior dome light fading effect... can I do it to my car?
    Feb 2005
    Milpitas, CA
    68
    I was wondering if anyone knew how to make interior dome lights fade in and out like those luxury cars out there. You know what I'm talking about, right? Like when you unlock and lock the doors of a BMW or Lexus, the dome light inside doesn't just turn on and off, it uses a fading effect to turn on and off. With my civic, It just flicks on and off with no fading effect. Am I able to make my interior dome light fade in and out when I unlock and lock my doors? There must be a way to do that right? Please inform me... Thanks.
    "JDM CTR HID Retro-Fit" Check it out!
    Senior Member HID Learner Falcon's Avatar
    Mar 2005
    Snohomish, WA
    103
    I can't help you on where to find parts, but what you're looking for I'm fairly sure is a voltage(?) regulator. It's the same concept as the dimmer switches you can get for the car only automated. Gets the power source and slowly turns the power up to full and vice versa on turn off.
    The above statement is my opinion and my opinion alone... if you don't like it it's my opinion that you can bite me
    Senior Member HID Rookie MidShipCivic's Avatar
    Original HIDForum member - Central Florida
    433
    Shiroi hikari.
    Nov 2004
    Lynnwood, WA
    520
    it's really quite simple,
    a properly sized capacitor will do this affect,
    Back in IL!
    306
    Quote Originally Posted by xero
    Correct,
    A voltage regulator just cuts off when you get to a certain height.
    But what your looking for is a
    "Theater lighting" module.
    Nov 2004
    Florida
    55
    my civic came with that....
    My 2003 civic has that already. there may be a way to take one out of a wrecked car and put it in your car. That may be little easier and if you take the whole dome light assembly, you will have map lights.
    Senior Member HID KING Lonnie91a's Avatar
    Jul 2005
    British Columbia
    1,369
    yes a capacitor wired on the positive lead would be the easiest way.. the capacitor stores a little bit of power.. when you close the door. the capacitor drains and the light dims and goes off. i cant wait to try it on my truck.
    "Saving the world, one retrofit at a time..."
    You need more than a capacitor, which will just drain instantly (you won't see any difference at all if you just put a capacitor across the bulb). The guy at webelectricproducts.com sells a module...
    Jul 2005
    British Columbia
    1,369
    Quote Originally Posted by Scheinwerfermann
    depends on the size of the capicitor.. you would need a rather large one.
  1. Luxeon 1 Watt LED Dome Light Review
    By dmiller5 in forum LEDs
    Last Post: May 20th, 2006, 02:09 AM
  2. Looking for small Xenon Fog light/driving light?
    By Kasteo in forum General Discussion
    Last Post: January 11th, 2006, 04:50 PM
  3. Interior retro
    By RPG4U in forum Projector Retrofits
    Last Post: April 28th, 2005, 05:37 PM
  4. Finished my interior LED mods. (pics)
    By mercurycougar in forum LEDs
    Last Post: February 25th, 2005, 12:44 PM
  5. Interior retro
    By RPG4U in forum General Discussion
    Last Post: January 12th, 2005, 02:07 AM
