Results 1 to 10 of 20
    Feb 2010
    20
    08+ WRX Retrofit Complete DIY
    To my knowledge, nobody has posted a full version. I would like to thank member CarbonXe for some helpful shots and tips. I have included my own tips and what not in my write-up. I recommend downloading it if you want more detailed photos. Google scaled them down a bit in the preview.
    In case you were wondering and did not want to click, I used:
    -MDX Projectors
    -Matsushita Gen 3 ballasts
    -Morimoto 5000K bulbs
    -TRS harness
    Hats off to the Retrofit Source for putting this awesome package together.
    I also put in the Lightwerkz angel eyes.
    Full write-up from the very beginning:
    https://docs.google.com/fileview?id=...ZDlmNjk2&hl=en
    Feb 2010
    20
    Just a heads up. When you are putting TSX-R lenses in, you want to orient the 5 scored things (they are turned incorrectly to the right side in the picture below) such that they are pointing down. This will ensure a clean cutoff and help disperse a minute amount of light upwards so that you can read street signs better, hence the name "sign light".
    Moderator HID FANATIC haknslash's Avatar
    Crimson Tide state
    7,652
    I added it to the vehicle retro database
    Feb 2010
    20
    Thanks! I appreciate it!
    Nov 2006
    England
    476
    Thats a very impressive detailed how to. What is up with the right projector? the right side of the cutoff appears to lack width as it seems distorted/restricted?
    Golf III VR6 Highline - currently AP1 S2000 retro in InPro R32 look lights, 4 stage Adjustable Boosted Bosch ballasts 35W-68W
    Feb 2010
    20
    I am not sure. I thoroughly cleaned everything when I was putting it all back together. My best guess is that the sign light I described above is oriented the wrong direction and may have caused a strange light dispersion causing some distortion. Although obvious here, it seems alright while driving. Perhaps if I get bored, I will bust it open again and look into it.
    Senior Member HID Nut mnb22's Avatar
    Dec 2008
    Cairo, Egypt
    753
    try to switch the bulbs and see if this will fix the passenger side cutoff, I am suspecting the bulb is off center
    Senior Member HID Nut devani's Avatar
    Dec 2006
    NJ
    683
    that's one great looking retro....FX-R is 50:50 on getting the output leveled....
    My feedback...lol I know
    http://www.hidplanet.com/forums/view...812&highlight=
    09 Civic SI Alabaster Silver Metallic Sedan
    01 Civic EX Coupe 5 Speed RIP
    Feb 2010
    20
    Quote Originally Posted by mnb22
    MNB I tried to re-seat the bulb because I thought it may have been a little funky with the spacer. After that failed, I switched them and here is the result (I apologize for the cell pic)>
    Obviously it is an issue with the bulb. Is there anything I should do or do I need a new bulb? Thanks!
    Dec 2006
    NJ
    683
    it's not the bulbs...now the same thing is happening to the driver side...
  1. 96 Millenia Retro... Not complete yet but will be soon
    By reality1011 in forum Projector Retrofits
    Last Post: January 19th, 2005, 05:53 PM
  2. retrofitting the HIDPlanet complete Kit
    By DreamZs in forum General Discussion
    Last Post: January 11th, 2005, 06:54 AM
  3. Complete Parts for HID
    By TL-Ridaz96 in forum General Discussion
    Last Post: November 18th, 2004, 11:24 PM
  4. 98' Eclipse retrofit complete. Finally!!!!
    By mc_holla in forum Projector Retrofits
    Last Post: November 7th, 2004, 11:01 AM
