Results 1 to 3 of 3
Thread: Operating a LM7812 regulator below minimum input voltage
    Senior Member HID Learner etboost's Avatar
    Jun 2006
    ny
    162
    i got question about LM7812
    whats min input voltage? If min voltage below required, it won't regulate output? need clarifications
    thanx...
    Senior Member HID MASTER azdave's Avatar
    Arizona
    3,214
    Regulation mins
    I edited the thread title so others could find it easieer in a future search.
    Quote Originally Posted by etboost
    thanx...
    It will fully regulate and hold 12.0 volts output when you have about 13.5 volts or greater input.
    When the input is below 13.5 volts the output will be lower by about 1.5 volts. Example put 12.5 volts in and you get 11.0 volts out. 11 volts in 9.5 volts out. This is commonly called "head room".
    With a low-loss regulator (like the Sharp PQ12RD21) you put 12.5 volts in and you get 12.0 volts out. It only needs 0.5 volts headroom to fully regulate.
    Read my first post in this thread.
    http://www.hidplanet.com/forums/viewtopic.php?t=48086
    Jun 2006
    ny
    162
    ok, thanx Dave...
  1. Replies: 7
    Last Post: March 14th, 2005, 11:32 AM
  2. Replies: 10
    Last Post: January 19th, 2005, 02:23 PM
  3. type of regulator
    By geo1317 in forum LEDs
    Last Post: January 17th, 2005, 08:42 PM
  4. Replies: 2
    Last Post: January 10th, 2005, 01:16 AM
  5. Voltage Regulator
    By dmiller5 in forum LEDs
    Last Post: November 19th, 2004, 08:59 PM
