Page 1 of 17 1234567891011 ... LastLast
Results 1 to 10 of 161
Thread: Projector Comparison:TSX,S2K,SC430,RX330 LS430,TL,E55,FX etc
    Senior Member HID KING JVX.'s Avatar
    Mar 2008
    Socal
    1,212
    Here's a comparison of some of the popular projectors in the market right now. I included both single and bi-xenon. In this post, I only compared lowbeam output. In the future, I will add more pics to include new projectors, after-market projector, custom shield, and other hybrids.
    Car parked 35ft from wall in well lighted background. 3 shots taken for each projector, at 50ft, 35ft, and 10ft. I'm using Nikon D60 with ISO800, Speed 1/4" and Aperture 8.0 with a tripod. All projectors uses Philips 85122+ 35W D2S bulb and Matsushita Gen 3 35W ballast. Exceptions will be noted, as in the case of pnp projectors using non-oem bulbs.
    At 50ft to Capture Entire Beam Spread
    TSX - Oem Clear Lens and Oem Curve Shield:
    S2K - TSX-Replica Clear Lens and Oem Curve Shield:
    SC430 - Oem E30 Clear Lens and Oem Curve Shield:
    SC430-f/RX330-b Hybrid - Oem E30 Clear Lens and Oem Curve Shield:
    RX330 - Oem E30 Clear Lens and Custom Curve Shield:
    LS430 - TSX-Replica Clear Lens and Oem Curve Shield:
    TL - Oem ZKW e46 Clear Lens and Oem Semi-Curve Shield:
    E55 - ZKW-Replica Clear Lens and Oem Semi-Curve Shield:
    Murano - STi-Replica Clear Lens and Oem Curve Shield:
    FX - FX-Replica Clear Lens and Oem Double Curve Shield:
    IS250 - STi-Replica Clear Lens and Oem Curve Shield:
    ZKW e46 - Oem ZKW Clear Lens and Oem Straight Shield:
    LR3 - STi-Replica Clear Lens and Oem Semi-Curve Shield:
    Q45 - Oem Multi-Lenses and Oem Multi-Curve Shields:
    IS250/RX330 Hybrid - STi-R Clear Lens and Oem Curve Shield:
    PnP G1 - Clear Lens and Curve Shield:
    PnP G3 - Clear Lens and Curve Shield:
    Replica FX - FX-R Clear Lens and Curve Shield:
    PnP Mini H1 - FX-R Clear Lens and Curve Shield:
    A4 Single Valeo - Oem TSX Clear Lens and Oem Flat Shield
    A6 - Oem e30 Clear Lens and Oem Flat Shield
    X5 (e39) - Oem ZKW Clear Lens and Oem Flat Shield
    35ft In Front of Car
    Closeup Shot at 10ft
    Please do not take these pictures as-is. Do your own testing to verify the output. With additional spacing, centering, and tilting, you can get better output, sharpness, color, intensity, straightness.
    Not all projectors and lenses are the same, even from the same maker. Some projectors have more light bleeding above the cutoff, making the wall appears brighter. But all pics are taken with the same camera settings. Also, these pics are taken in a very well lighted area. The cutoff would have been better in a darker environment.
    Lastly, if you want to compare these pics to one another, I recommend downloading them into separate tabs and then click each tab to jump from pics to pics. You will can see the difference between them better than just scrolling up and down. Finally, do NOT reply to this first post. You don't want to include all the pics again. Enjoy.
    very nice pics, you can clearly see how much the tsx sucks. almost as bad as is250 lol. the rest of them are pretty close but s2k, TL, sc430, and modded rx are the best. the fx mountain looks terrible.
    Jul 2008
    WI
    69
    Awesome compilation. Glad you decided to combine them all. This should be stickyed.
    1984 Honda Sabre Retro
    - Single 7" Headlight
    - 1 Murano Bixenon
    - STi-R Clear Lense
    - Potted Denso Slim
    - 85122+
    Jan 2007
    112
    Is it me or it looks like the sc430 is brighter than the s2k?
    Mr. Clean Beam HID MASTER greenkouki's Avatar
    May 2005
    NC
    4,336
    Quote Originally Posted by tchan1
    no
    but the rx330 has better width/intensity than the sc
    *I will be unavailable until July for projector modding/retrofits*
    Need your s2k, rx330, rx350, mdx, maxima, rx8, miata, 4gTL or sti projectors modded for better performance/cutoff? PM me.
    Sep 2007
    Houston, TX
    734
    tsx clear lens is over rated somehow since they are not clear as tsx replicas.
    you rather get rx330 with tsx replicas with custom curved shields. yields better results such as greater width for about same price.
    Dec 2008
    48
    Quote Originally Posted by aznboi89x
    Not same price if you are up north
    How can you tell if you have TSX clear replica or tsx clear oem?
    funkbro2
    Honda Accord 7G retrofit in progress (Denso ballast, TSX Clear lens projector, E46 Shroud so far)
    Sep 2007
    Houston, TX
    734
    Quote Originally Posted by funkbro2
    tsx replicas have a flutted section on the side.
    Dec 2005
    389
    Still trying to figure out why the s2k is so expensive? Theres a couple up there that are almost equal to it.
    Sep 2007
    Houston, TX
    734
    expensive cuz they are wide. like JVX said its different for complete darkness and angle and such.
    if you actually took two pairs of s2k and compared it to lets say a pair of tsx.
    its a big difference once you have two setups retro'd in. also take into account about your headlight lens how they are. headlight lens are a big factor taking away the color and sharpness. even if your lens are nice and clear, its how your lens are positioned, straight up and down or curved or slanted.
    look at jvx's s2k on his crx or somewhat he had and it was DAMN WIDE!
  1. RX330 retro on a 2002 tacoma [PICS]
    By MTK Kommander in forum Projector Retrofits
    Last Post: January 6th, 2005, 09:50 PM
  2. FX bi-xenon & S2000/SC430 into Accord 01 V6 HLs POSSIBLE
    By JackNg in forum General Discussion
    Last Post: December 5th, 2004, 02:58 AM
  3. projectors comparison
    By lovehids in forum Projector Retrofits
    Last Post: October 26th, 2004, 04:34 PM
  4. Mercedes W124 E420 Comparison (picts)
    By LEDZ in forum General Discussion
    Last Post: October 13th, 2004, 10:44 PM
  5. LEXUS SC430 Projectors: GOOD?
    By wcbcruzer in forum General Discussion
    Last Post: October 5th, 2004, 07:42 PM
