Results 1 to 6 of 6
Thread: How to tell if bulb is burnt out?
    How can i tell if the bulb is burnt out? will it be black like a regular halogen bulb?
    Administrator HID FANATIC@#$! gearbox's Avatar
    19,233
    its hard to tell, but usually when a bulb gets very old like 5-6 yrs or lots of hours, there is a white puffy cloud in the capsule. almost like a cotton piece.
    Apr 2007
    812
    A quality OEM bulb really dosent ever 'burn out' They just generally go for 10+ years and then turn purple and put off 50 lumens.
    If the capsule is relatively clear, then it is likely fine. If it is very hazed, then it might be bad.
    If the bulbs are over 2 years old, i would replace them with new anyways.
    ok one question, when i turn my lights on, the driver side dosn't light up and i cannot hear the buzzing sound from the ballast. the passenger side works and i can hear the buzzing. so my question is, if the driver side bulb is burnt out, will i still hear a buzzing? since i am not hearing a buzzing, does that mean that its my ballast or wiring thats the problem?
    19,233
    possibly the bulb exploded. i would check. but dont go reaching around with your hands cause glass pieces might poke you. just pull the base out and look.
    Senior Member HID Nut STD Toledo's Avatar
    Jul 2008
    Greece, Athens
    735
    If you need to be 100% sure if your bulb is burnt, then do the following: exchange bulbs. Connect the "burnt" bulb with the ballast of the other (good working bulb). If the "burnt" bulb works fine, then it's the ballast's problem. If it has the same (non) operation, then it's the bulb.
    Easy and safe method called: "trial and error" !...
    Costas
    SEAT Toledo 1.6 16v S-Line RX-330AFS | Osram 66240CBI | OEM Fog 4300K | DRL Led | Led Night Pack
    "that set up is lighting sex": http://www.youtube.com/watch?v=gm9M-m4mCZ4
  1. matrix bulb & bulb flashers...
    By ej76623 in forum LED's
    Last Post: March 27th, 2006, 06:43 PM
  2. Burnt headlight bulb?
    By nicklbrso in forum General Discussion
    Last Post: September 25th, 2005, 05:22 PM
  3. How can you tell if the d2r bulb is burnt out? Visual look
    By j8y-unit in forum General Discussion
    Last Post: August 6th, 2005, 04:15 PM
  4. 1 Bulb, 2 Bulb 3 bulbs.....
    By in forum General Discussion
    Last Post: May 14th, 2005, 03:52 AM
  5. Burnt plastic on bulb, small spot
    By Civicsilover43 in forum General Discussion
    Last Post: February 17th, 2005, 06:28 PM
