Thread: 9007 HID Question for a Saturn Ion
    May 2008
    5
    I would like to install a HID kit on my Saturn Ion coupe that uses the 9007 bulbs. From what I have seen on some Ion related forums is that some people have trouble with the high beam indicator constantly being illuminated when using a bi-xenon kit, and I believe even a low beam kit. I haven't really been able to get a straight answer on which kits cause the high beam inidcator to stay on, but I want to avoid it by all means.
    I've been thinking of the McCullouch 6000K kit, and I would like to go bi-xenon. Has anyone here installed this kit on a Saturn Ion and had any trouble with it, or any other car equipped with a 9007 bulb? Is there any way around having the high beam inidcator always being illuminated with the lights on?
    Senior Member HID Nut Biggie862005's Avatar
    Jan 2008
    Massachusetts
    509
    a relay harness may solve the problem..... :-k
    E55 Retrofit | 85122 | "Ebay" Ballasts...
    "Im just glad we got to see eachother, talk and re-meet eachother, Save a place in heaven till the next time we meet forever." 08/01/62-12/31/03
    May 2008
    5
    Quote Originally Posted by Biggie862005
    Is that something that I'll need to make, or can they be purchased premade?
    I don't think this problem happens with all of the kits, just some. Has anyone here installed a bi-xenon in an Ion without any problems after?
    Jan 2008
    Massachusetts
    509
    you can either buy or make one depending on your electrical expertise.... i bought one: http://shop.3bspecialties.com/produc...&categoryId=10
    just select bulb type,9007 and your good to go, and i would recommend using one if you plan on buying a hid kit.
    May 2008
    5
    I'll have to look into that.
    I'm assuming this problem would happen with any vehicle with 9007s if it did happen. has anyone else installed a 9007 bi-xenon kit without any troubles of the bright indicator?
  1. I need a 9007 bi-xenon wiring harness
    By Civicsilover43 in forum Wiring Questions
    Last Post: September 18th, 2006, 10:25 AM
  2. Lowest cost HID kit, 9007 Ford Ranger?
    By gsxr150 in forum General Discussion
    Last Post: January 2nd, 2005, 08:51 PM
  3. help with 9007 HID conversion buying
    By tanly03 in forum General Discussion
    Last Post: December 26th, 2004, 01:20 AM
  4. d2s to 9007 will this work and how?
    By thelostbrian in forum General Discussion
    Last Post: November 23rd, 2004, 11:47 AM
  5. 9007 wiring harness
    Last Post: September 9th, 2004, 09:15 AM
