Results 1 to 8 of 8
Thread: Philips 85123 D2S bulb?
    Senior Member HID Guru JLUDE's Avatar
    819
    What is the difference between Philips 85123 and 85122. Will they match in color if used together?
    '00 Tacoma 4x4, '02 S2000, '06 FZ6: 3 vehicles, 3 sets of OEM HID projectors. Seeing is believing!
    Senior Member HID KING sy272004's Avatar
    Mar 2007
    Philly
    2,008
    i think 123 are the 6000k once(ultilion i think the name and 2400lumens) 85122 are 4300K 85122+ are 5000k so no they will not match color if used together unless 85122 is very old and color shifted couple times (thats what 85122+ is for, to replace bad 85122 and so it would match color so you wouldnt replace both at same time)
    85122 are 3200lumens 85122+ around 3000lumens.
    as far as i know
    here is something i found, had to translate it from russian
    http://intercar.com.ua/forum/viewtopic.php?t=1028
    later found here
    D4 bulbs require D4 type ballasts, will not work with d2 or d1 type ballasts
    42402 Philips D4S 4800K 3200lm (Hg free)pure white, 42V.
    42402 V269 Philips D4S 5800K 3300lm (Hg free), snow white 42V.
    42406 Philips D4R 4800K 3800lm (Hg free), pure white 42V.
    66040 Osram D2S 4150K 3200lm, DOT approved, yellow-white Xenark
    66043 Osram D1S 4150K 3200lm, DOT approved, yellow-white Xenark
    elektronic 35W
    66050 Osram D2R 4150K 3200lm, DOT approved, yellow-white Xenark.
    66053 Osram D1R 4150K 3200lm, DOT approved, yellow-white Xenarc electronik 35W
    85122 Philips D2S 4100K 3200lm, DOT approved, yellow-white.
    85122+ Philips D2S 5000K, DOT approved, yellow-white, white with tint of yellow (color match) CM (plus)
    85122WX Philips D2S 5800K Ultinon 2400lm pure blue violet white.
    85123 Philips D2S 4900K color reminds color of Ultinon, pure white, whithout yellow ( most likely specialy for BMW)
    85126, same as 85122, but D2R
    85126+, same as 85122+, but D2R
    85407 Philips D1S, built in starter, rest same as 85122.
    85407+
    Philips D1S, built in starter, rest same as 85122+
    85408 Philips D1R, built in starter, rest same as 85122
    85408+ Philips D1R, built in starter, rest same as 85122+
    hope it helps
    http://www.v6performance.net/forums/...ad.php?t=90272
    My Feedback
    http://www.hidplanet.com/forums/viewtopic.php?t=40647
    EliteCM.net 7th gen Accord forum
    819
    That's helpful, thanks but 85122+ are not 5000K. They are closer to 4100K. My 85122's are bluer than 85122+
    - J
    Mar 2007
    Philly
    2,008
    Quote Originally Posted by JLUDE
    - J
    then your 85122 most likely already color shifted couse 85122 supposed to be bluer then 85122.
    My Feedback
    Dec 2006
    Spartanburg, SC
    125
    Yea, 85122+ bulbs are definately not 5000K there are bulb spec sheets with the actual color temp if you search a little.
    85123 was a good bit bluer/whiter than 85122 if they have the same amount of usage. Just get another 85122.
    85123 is a 4800k bulb made for some bmws. but i couldnt tell any difference in color to a + bulb.
    Oct 2006
    277
    I just got some Ultinons (85122WX), I'll post pics this weekend to compare them with 85122 and 85122+
    My 4Runner: the never ending retro. Once you start you can't stop...
    1st: FX. 2nd: TL 3rd: ...?
    My seller feedback
    can you do side by side comparison with one in each housing?
  1. Best place online to find a 4300K Philips H3 KIT?
    By DJ Hellfire in forum General Discussion
    Last Post: December 23rd, 2004, 07:17 PM
  2. Where to buy Philips Vision Plus bulbs?
    By Y2A in forum General Discussion
    Last Post: November 19th, 2004, 12:39 AM
  3. When are Philips 4k bulbs the brightest?
    By kenghk in forum General Discussion
    Last Post: November 5th, 2004, 06:04 PM
  4. Best place online to find a 4300K Philips H3 KIT?
    Last Post: October 23rd, 2004, 11:40 AM
  5. philips or osram
    By samlindsay in forum General Discussion
    Last Post: October 4th, 2004, 03:30 PM
