Thread: How does the OEM Bi-xenon projector work? retrofit questions
    i bought some infiniti fx35 bi-xenon projectors off ebay because i want to use the projectors, not the crappy h4 housings that i have right now. here's a link to the set that i got.
    1. how does the projector and HID system work exactly? does the system use a standard bulb and the projector uses it's shutter to dim the light down for the low beam? or does it use some kind of dual bulb setup like the aftermarket h4 bi-xenon bulbs?
    2. are bi-xenon ballasts the same as single beam ballasts? if i buy a d2s bulb with harness to be able to hook up to an aftermarket ballast, can i buy any single beam ballast?
    3. is the difference between the aftermarket bi-xenon and single beam kits just the bulb? from what i've seen, most kits have some sort of bulb that moves for the high/low beam.
    thanks for helping a newbie out
    Senior Member HID Nut CBRrider's Avatar
    Jul 2007
    PHX,AZ
    609
    man you did it backwards,should of done some research before buying something,anyhow there is tons of info on here check out the university section,that should answer all your questions,also the FAQ has alot of good info too,good luck with your retro
    NO SQUID HERE
    my feedback;
    http://www.hidplanet.com/forums/viewtopic.php?t=37426
    my first led project; Toyota Pickup fr turn signals
    http://www.hidplanet.com/forums/view...842&highlight=
    Toyota pickup retro, 7x6
    http://www.hidplanet.com/forums/show...tro-with-MH1-s
    thanks. i don't really see how i "did it backwards." i bought the projectors and they're bi-xenon projectors. i can always remove the shutters and use them with a standard kit. i just wanted to see if i could keep the high beams.
    Senior Member HID KING striker_1818's Avatar
    Long Island, New York
    2,490
    bixenon projectors are like single-xenon projectors. However, these have a shield that move up and down. Everytime you hit your high beams, the solenoid will move.
    With that said, you only need a set of ballasts and bulbs then hook up your hi-beam wiring to the solenoid to activate them.
    You don't need bixenon ballasts. Any D2S ballast will do.
    Quote Originally Posted by striker_1818
    EXACTLY the kind of response i was hoping for. thanks so much!!
  1. ebay projector retrofit questions
    By David526 in forum General Discussion
    Last Post: November 17th, 2008, 10:04 AM
  2. HID projector retrofit questions
    By blown_volvo850r in forum General Discussion
    Last Post: February 15th, 2007, 05:33 PM
  3. TSX projector retrofit questions
    By 555itr in forum General Discussion
    Last Post: February 9th, 2007, 12:44 AM
  4. Retrofit a Bi-xenon projector into stock 04 Ram headlights
    By poolshark2014 in forum General Discussion
    Last Post: April 20th, 2006, 04:52 PM
  5. ZKW bi-xenon projector questions
    By maximus96 in forum General Discussion
    Last Post: April 7th, 2005, 02:12 AM
