Results 1 to 10 of 10
Thread: What is the difference between 'H' bulbs and 900x
    Junior Member
    Mar 2007
    Raleigh, NC
    24
    What is the difference between 'H' bulbs, such as H1, H3, etc, and 900x bulbs, like 9004, 9006, 9007?
    Does every 900x bulb have a comprobable H bulb, just a different base?
    Thanks!
    Senior Member HID FANATIC@#$! linuxglobal's Avatar
    Nov 2005
    Southfield, Michigan | Halton Hills, Ontario
    9,590
    they are all H bulbs = halogen.
    THey just have diff abbreviations.
    9006 = low beam = hb4
    9005 = high beam = hb5
    9004 is something like hb5
    9007 is hb3
    Some others are purely devoted to fog use like h3 and 881, 894, you will rarely see these in lows (oem lows anyways) ebay doesnt count.
    The best filaments to be replaced with hid include 9005 and 9006 whenever used as fog or high beams.... low is debatable in 9006... depends on the car.
    But the H always stands for halogen.
    Junior Member
    Mar 2007
    Raleigh, NC
    24
    makes sense
    so if you have, say, a civc, with H1 headlight bulbs, can that be replaced with a 9003 HID conversion kit?
    Senior Member
    Wisconsin baby!
    733
    9005 = hb3
    9007 = hb2
    i know the first one is right (since its on my headlights lol, but im not 100% on the 9007...)
    Nov 2005
    9,590
    Quote Originally Posted by mikemjohnson
    makes sense
    not sure what 9003 is ... if its h1 then ure fine.
    Senior Member HID Nut taco's Avatar
    Feb 2005
    wv
    595
    9003 is h4.
    Senior Member
    May 2005
    South San Francisco
    605
    Re: What is the difference between 'H' bulbs and 900x
    Thanks!
    900x bulbs tend to have plastic bases. (which can melt from overwattage bulbs or HID kits)
    9004 is dual transverse filament 45w/65w (low/high)
    9005 is single longitudinal filament 65w (high)
    9006 is single longitudinal filament 55w (low)
    9007 is dual longitudinal filament 55w/65w (low/high)
    H bulbs are a mixed bag
    H3 is an outright weirdo.
    Senior Member Azrael's Avatar
    Dec 2005
    Manitoba, Canada
    189
    All headlight/foglight bulbs that are identified by just numbers use a twist-lock base whereas H1, H3, etc bulbs are typically held in place with screws or springs and require specific orientation.
    Senior Member
    May 2005
    South San Francisco
    605
    Quote Originally Posted by Azrael
    I forgot how the H9, H11, H13 looked. Didn't want to jump to those conclusions.
    H11 is a twist lock
  1. Difference between bulbs
    By fieldgoal00 in forum General Discussion
    Last Post: February 4th, 2010, 02:06 PM
  2. The difference b/n bulbs?
    By spinnaz in forum General Discussion
    Last Post: April 24th, 2008, 12:37 AM
  3. Difference between these bulbs?
    By mj1220mj in forum General Discussion
    Last Post: August 19th, 2007, 04:21 PM
  4. Difference in bulbs?
    By layzie in forum General Discussion
    Last Post: February 2nd, 2007, 02:25 PM
  5. difference between d2s and d2r hid bulbs ?????
    By amgstyle in forum General Discussion
    Last Post: November 8th, 2004, 01:54 PM
