Results 1 to 4 of 4
Thread: How to troubleshoot ballast?
    I just bought a retro from a member on this site, and i installed everything in my car... and my light does NOT come on. I unplugged the wired that plugs into the ballast and hooked it up to meter and it reads 12.6v, so i know it has to be something to do with ballast or a bulb. How can i figure out if its bad bulb or ballast? How can i check if ballast is putting out power to bulb?
    I had a loose connection. Now when i turn my light both my d2s bulb flicker really quick and turn off. Its seems like ballast is sending signal to turn it on or something.
    Senior Member HID Nut pks485's Avatar
    Oct 2005
    NYC & PHILLY
    587
    Quote Originally Posted by kickercivic1
    Did you try hooking a ballast up directly to the battery? Are both ballasts failing to work. If so than it could be your wiring instead of the ballasts.
    |Rx330 AFS W/Clear Lens|Maxima Fogs W/Removed Shields For High Beams|Blazer Fogs|
    Supercharge a Bosch Ballast in 5 Easy Steps
    Thx for help. Problem was the connector coming from the ballast hooking up to bulb. It was atcually it was my fault, I didn't plug it in tight enough. Searching on hidplanet and this site http://faqlight.carpassion.info/hl-hid-ballasts.htm
    help me solve my problem.
  1. Hella Ballast vs Denso Ballast vs Mitsu Ballast
    By jmb86 in forum General Discussion
    Last Post: March 9th, 2014, 07:02 PM
  2. Hids troubleshoot...i need your help!
    By zed33 in forum General Discussion
    Last Post: March 16th, 2007, 08:31 AM
  3. Ballast just stopped working for no reason(Bosch AL Ballast)
    By Vince126 in forum General Discussion
    Last Post: October 10th, 2006, 07:12 PM
  4. Postive wire touched ballast casing.. now ballast wont work
    By JDMLyfestyles in forum General Discussion
    Last Post: July 11th, 2006, 02:34 AM
  5. how can i hoook up 24vdc ballast? it is hella gen3 ballast
    By pho1982 in forum General Discussion
    Last Post: December 2nd, 2005, 07:42 AM
