Thread: Lexan, will it melt?
    Senior Member HID FANATIC linuxglobal's Avatar
    Nov 2005
    Halton Hills, Ontario || Niagara Falls. NY
    5,886
    So basically, will lexan melt if placed in front of this lamp?? any major chipping or shattering that i should expect. I plan to cut out a lexan piece and stick it in front of the projector lens. not touching but really close. That way the lens is protected from road chips. Will lexan work, what can i use to glue lexan? It has to be clear since the glue will be visible.
    This is what the fog lamp looks like. The plastic circle would fit over the lens to protect it from road chips.
    THis is a blazer unit that will run a d2s kit.
    Thanks in advance.
    Aug 2005
    CANADA
    359
    It wont shatter or break. Make sure it's not on the focal point of the projector or it will melt it or yellow it. That is if the foglight is a real projector, not a projector look-alike. You can find the focal point in front of the lense by putting a piece of paper and look where the pattern converges to a point.
    Nov 2005
    5,886
    Quote Originally Posted by NOTSOFAST
    Could i use high temp silicone??? to glue into place.
    this is what i plan to do.. now keeping in mind the focal point.
    Aug 2005
    CANADA
    359
    Clear silicone would be fine. Just run a thin bead so it's no going to get allover the place but enough to seal all gaps ! :drinkers:
    San Francisco, CA. USA
    1,118
    Polycarbonate.. lexan wont melt in front of the beam pattern. It has a forming temp of about 350+ and ur lighting unit wont get anywhere near that temp especialy if it's not touching it.
    Make sure you face the lexan with the uv protected side on the outside so to protect the uv from the sun. On the inside there's no uv being exposed so no worries there.
    Best Regards,
    Larry
    Driving fast is having the highest acceleration in the appropriate direction
  1. Where to buy clear lexan?
    By rpeirats in forum General Discussion
    Last Post: October 11th, 2007, 07:29 PM
  2. mr10 lexan?
    By b1m2x3 in forum General Discussion
    Last Post: June 6th, 2007, 05:05 AM
  3. How do I use LEXAN?
    By bixenon in forum General Discussion
    Last Post: March 25th, 2007, 10:21 PM
  4. Glueing lexan
    By MrBiXenon in forum General Discussion
    Last Post: May 22nd, 2006, 04:36 PM
  5. Anyone worked with Lexan MR2?
    By mase in forum General Discussion
    Last Post: October 1st, 2004, 03:45 PM
